Hi - I don’t know if I should ask this here or in a Gnome 2 forum, but the handiest accessory I really miss is the mouse parking panel applet back from 8.04 Gnome2 - does anyone know what ever happened to it, and if there is a substitute applet I could modify to perform the same function. What I do find is that even though I have checked the “disable touchpad while typing” checkbox selected, it has never worked properly for me - and this is with 3 laptops since then!
Thanks in advance for any help you can give me!
Could you please be more specific with applet naming and Ubuntu version?
I have installed 8.04 LTS and I do not see any Mouse applet here (but gnome-applets
package with 2.22 version is installed).
Are you sure that it was GNOME thing? Do you have its screenshot?
@johnf - never heard of this applet, but it sounds interesting. Based on your description it sounds as though it’s a spot in the panel where of you move your mouse pointer to it, and it stays “stuck” or “parked” there until presumably you press a hot key. Does that sound like what you want?
Again, never heard of it and as far as I know has never been an official part of GNOME, but it seems like it would be an easy applet to make.
Hi - I think it was 8.04 - could have been 11.04 or even 11.10 - I can’t remember for sure, since it was so long ago. The applet I’m talking about was a parking space for the cursor - when you hovered over the parking space (in the panel) and clicked the mouse button (or touchpad button) the cursor movement was disabled until you clicked the button again. It allowed easy text entry, without your palms interfering with the text entry by moving the cursor all over the place as you typed I can’t remember exactly what it was called - I may have an old 8.04 live desktop laying around and boot it up to see what it was called. Thanks for responding so quickly
update: I booted 11.04 and found the applet and the package it is in - it is called a “pointer capture applet” and it is part of mousetweaks.3.0.0-0ubuntu2. I have the current mousetweaks installed, 3.12.0-4 which claims to have the same funtionality, but if it does, it does not integrate that with the gnome2 panel applet selection menu. In 11.04, the pointer capture applet is displayed directly by in the applet menu, but on everything subsequent (after 12.04) that functionality has disappeared with Gnome2 panel. I dont know how to set it up in a command line - there does not seem to be enough options in the man page to allow that kind of setup (with the latest release anyway) - I think I will try to force the old version to be installed and see if that works - I’ll let you know!
update #2: I tried to install mousetweaks_3.0.0-0ubuntu2, but it has depenency, libpanel-applet-3-0. Can’t find that anywhere ( I also searched through oldreleases.ubuntu.com but was unsuccessful. I already have libpanel-applet3 installed, but I think that is a different library. I’m gonna keep buggering around with this for a while, since it is a very useful applet that does not work anymore for some reason. I’ll let you know in the future sometime!
The lost screenshot of Ubuntu Natty with Pointer Capture Applet:
Its man-page:
NAME
pointer-capture-applet - Creates an area on the panel to capture the pointer
SYNOPSIS
DESCRIPTION
The Pointer Capture applet is part of the mousetweaks package. It creates an area on the panel which can capture the pointer until the user
releases it with a predefined button and modifier key combination.
BUGS
Report bugs to <http://bugzilla.gnome.org/> ⟨http://bugzilla.gnome.org/⟩
AUTHORS
pointer-capture-applet was written by Gerd Kohlberger. This manual page was written by Francesco Fumanti.
LICENSE
Licenced under the GNU General Public License v3 or later.
SEE ALSO
mousetweaks(1), dwell-click-applet(1)
pointer-capture-applet(1)
Below is a screenshot with locked mouse:
Technical details.
This applet comes from mousetweaks
package:
$ apt-cache policy mousetweaks
mousetweaks:
Installed: 3.0.0-0ubuntu2
Candidate: 3.0.0-0ubuntu2
Version table:
*** 3.0.0-0ubuntu2 0
500 http://old-releases.ubuntu.com/ubuntu/ natty/main amd64 Packages
100 /var/lib/dpkg/status
$ dpkg -L mousetweaks | grep bin.*applet
/usr/bin/pointer-capture-applet
/usr/bin/dwell-click-applet
Its source code for 11.04 (natty) is located on the corresponding branch on launchpad. Theoretically it should work on 11.10 (oneiric), but this functionality was not compiled (oneiric branch is here). It is known that functionality was removed from 12.04 LTS (as it has GNOME 3.4).
Oneiric and Natty configure scripts have two options related to these applets:
--enable-pointer-capture Enable pointer-capture applet
--enable-dwell-click Enable dwell-click applet
The main problem with it - it uses old GNOME 2.32 and dependencies from it. But modern systems have GNOME 3.
I tried to install older mousetweaks
with hacky way on Ubuntu MATE 14.04 LTS, 16.04 LTS and 18.04 LTS by the following commands:
sudo apt-get install liborbit2 libgconf-2-4
wget http://old-releases.ubuntu.com/ubuntu/pool/main/g/gnome-panel/libpanel-applet-3-0_2.32.1-0ubuntu6.5_amd64.deb
sudo dpkg -x libpanel-applet-3-0_2.32.1-0ubuntu6.5_amd64.deb /
wget http://old-releases.ubuntu.com/ubuntu/pool/main/m/mousetweaks/mousetweaks_3.0.0-0ubuntu2_amd64.deb
sudo dpkg -x mousetweaks_3.0.0-0ubuntu2_amd64.deb /
and as the result pointer-capture-applet
and dwell-click-applet
do not crash but do not work too (not shown anywhere). So MATE desktop do not detect these applets.
@vkareh , @Wimpy What do you think - is it possible to create proxy-applet, which allows to place old GNOME2 applet to mate-panel
? Do we have any?
This is a great find! The file is there in the repo: /src/pointer-capture-applet.c
- it would need some massaging to get it working for mate-panel, but it seems doable.
Thank you for investigating this further! I have not been successful in my attempts, but you guys are way ahead of me! I’ll follow this thread for any developments. I don’t know how many people used the pointer applet, but it was sure handy in it’s time!
John
I have good news - I got got mousetweaks
compiled on Ubuntu 16.04 LTS MATE.
Below is complete instruction.
You need to download archive (mousetweaks-mate.tar.gz) with source code to your
~/Downloads
folder. It is manually patched bzr-code from natty. -
Then install all necessary dependencies:
sudo apt-get install build-essential intltool gnome-doc-utils rarian-compat \ libmate-panel-applet-dev libgconf2-dev libgtk2.0-dev sudo apt-get build-dep mate-applets mousetweaks
Extract archive, compile software and install it to system
cd ~/Downloads tar -xf mousetweaks-mate.tar.gz cd mousetweaks-mate ./configure --enable-dwell-click --enable-pointer-capture make sudo make install
Note: if you want to remove it - run sudo make uninstall
in the ~/Downloads/mousetweaks-mate
folder.
The result is shown on screenshot:
Currently I can't compile on 18.04 LTS because of Gtk2<->Gtk3 mess (it do not want to compile on 18.04 LTS, and installing version from 16.04 LTS ends with crash caused by GTK+ 2.x symbols detected. Using GTK+ 2.x and GTK+ 3 in the same process is not supported
as the result).
@Norbert_X this is brilliant! I will give it a try on my side as soon as I get a chance.
Off topic question, what’s your host system with the orange-brown old-school looking title bar?
Fabulous - I did get it to successfully ./configure after I added the gsettings development files, but unfortunately as you have indicated, it will not install because of the GTK issue, but I also had to add a lot more dependencies than you listed here (probably because I don’t do much compiling on this computer) and now my teminal history doesn’t go back far enough to remind me what else I had to install !!
That old feisty destop is pretty cool!
It would be great!
On host I’m using Ubuntu MATE 16.04.5 LTS with Human-Clearlooks theme (from human-theme
official Ubuntu package). But it is gray on 18.04 LTS. So I’ll stay on 16.04 LTS for a while.
Ah, of course! GTK3 changed how theme colors are handled, and this is a GTK2 theme…
I’m not that much familiar with GTK+, but it’s possible to refurnish the /src/pointer-capture-applet.c
code to work with GTK+ 3 by following the necessary migration steps, right?
I’d love to give it a go after my exam finishes tomorrow; I will have some time to kill, and this looks like a sweet opportunity!
@Apollonius - there’s not much to change, actually. Here’s most of what you need:
https://developer.gnome.org/gtk3/stable/gtk-migrating-theme-GtkStyleContext-engines.html
As well as some reference to GtkObject in a callback (just needs updating the function prototype). I’ve pushed a branch to launchpad: https://code.launchpad.net/~vkareh/+junk/mousetweaks
With apologies to @Norbert_X - who did all the porting work to MATE. I rebased it from the mousetweaks in oneiric and updated some things to GTK3. I’m not super familiar with bzr/launchpad, so I’ll have to figure out a way to attribute that initial port in the commit logs to nrbrtx.
Anyway, the work is not done - I still haven’t managed to load it in the latest mate-panel in 18.04, but it seems to compile so far.
I’m interested in the whole procedure; after establishing a code, where should I compile and test this type of thing? I guess not on my native system, that bears the risk of screwing it up… should I do this on a VM? Or is there any other way?
Sorry if I’m bugging you too much!
Thank you very much @vkareh for the idea about Code on Launchpad. I uploaded patched natty’s (Gtk2) version to the corresponding branch and created PPA with recipe for it. For now I have binary packages.
On Ubuntu MATE 16.04 LTS patched mousetweaks
package may be installed with:
sudo add-apt-repository ppa:nrbrtx/mousetweaks-mate
sudo apt-get update
sudo apt-get install mousetweaks
On Ubuntu MATE 14.04 LTS patched mousetweaks
package may be installed by downloading deb-package from pool and installing it manually. This is because of PPA-build-dependency on compilation time.
Currently I’m not running any Ubuntu 18.04 LTS on daily basis.
I’ll try to use these applets on my Ubuntu 16.04 LTS systems
Thank you Norbert! do you have a signing key for your repository? unfortunately all my other machines here run vanilla gnome 14.04, so I can’t test it on those. I’d like to test on 18.04 if you think it’d work!
@johnf The Signing key is listed on PPA page under Technical details about this PPA link.
On Ubuntu MATE 14.04 LTS I have simply installed my package with
sudo dpkg -i ./mousetweaks*.deb
The key was not required.
@vkareh
May be to broad, and some off-topic, but I have questions.
What is the release plan of Ubuntu MATE development? Assuming that someone will port the old Gtk2 applets - will this work be in vain? Or will there not be a full transition to GtK3? What are its main causes? Will this at the same time preserve the traditional look of the desktop?
@Norbert_X - Both Ubuntu MATE and the MATE Desktop are fully transitioned to GTK3. And we’re constantly upgrading any deprecated functions from even GTK3 (we’ve actually dropped support for anything less than GTK3.22 for our latest builds, and currently discussing the transition to GTK3.24 in the future).
The traditional look and feel of the desktop is one of our top priorities, and everything has been preserved to the best of our abilities.
As for old GTK2 applets, like the pointer-capture one, those are third-party and don’t really belong to MATE, so we have no say there. It falls on the community to port them to GTK3 and make them available for others to use. If enough people care, it could be included in future releases, but adding applets carries a maintenance burden for @Wimpy.
As to whether porting mousetweaks to MATE/GTK3 is in vain, I would say: not if you use it! I’m personally curious as to how this applet works and what it does so I spent some time hacking at it. I’m not a big mouse user, so this applet might prove useful for me. That said, I feel there are people here who probably care about it a lot more than I do, but I’m happy to help in any way I can
This is what happens on 18.04. I downloaded and installed
mousetweaks_3.99.99-really3.0.0~70~ubuntu16.04.1_amd64.deb
synaptic says that it is installed the same package is installed
this is what happens:
xxxx@xxxx:~$mousetweaks
(mousetweaks:1947): GLib-GIO-ERROR **: 20:41:04.110: Settings schema ‘org.mate.mousetweaks’ is not installed
Trace/breakpoint trap (core dumped)
xxxx@xxxx:~$
The pointer capture applet is displayed in the panel menu but when you add it with the ‘add’ function, no pointer-capture app is generated - probably because mousetweaks is not running according to ps -aux (but the add pointer-capture function in the panel may be some process I really don’t understand)
Thanks for your investigation with this function!!
It’s good to know what the exact policy is - it’s a drag because I cant help with these updates (all these libraries and apps orders of magnitude more complicated than my very limited programming knowledge provides) And it’s also good to know about how you feel about it too!
Thanks also for providing this forum - I don’t know where I’d get these answers anywhere else!
