I am on an Acer laptop. Using UM from a USB connected SSD. All fine and dandy 99% of time over the whole last year. UM 17.10 with daily update. Expecting to install dual boot with 18.04 LTS.
Now.
If I connect wifi using the ACER Windoze 10 I get almost double bandwidth then connecting using UM from the SSD…
Can someone explain that for the non-tech I am ?
Thanks
W
Just questions not an explanation …
- How are you determining bandwidth?
- Is the USB connection affecting the measurement?
- Is it possible the tool used is different in Win than UM?
- Is network card driver the latest in both cases?
- Are the network settings the same?
- Bandwidth: merely by looking at the volume of Mb/s or Kb/s that are shown
- USB Connection? Effectively I wondered if the USB connection simply had as an effect to reduce the data transfer from the computer to the SSD; where is actually located the UM system monitor; so actually measuring what gets through the USB, not what gets through between router and computer. Don't know how to assess that.
- No idea. But my guess is that if different tools they should not show that large a difference in datathrough.
- Driver? yes
- Network setting? No difference.
Will be in a different location by Sunday - so I'll see if it shows to be different in anyway.
