Hi there
I need to install/compile a driver for my wifi usb stick.
Bus 001 Device 004: ID 148f:761a Ralink Technology, Corp.
I used this driver on my gentoo-raspberry without any issues, so I tried it
on mate too:
What I did so far:
sudo apt install git build-essential
sudo apt-get install raspberrypi-kernel-headers
rpi-update
#uname -r
4.14.29-v7+
If I go then in the driver source directory and do a
make
I get this error:
~/build/mt7610u$ make
make ARCH=armv7l CROSS_COMPILE= -C /lib/modules/4.14.29-v7+/build M=/home/astro/build/mt7610u modules
make[1]: Entering directory '/lib/modules/4.14.29-v7+/build'
make[1]: *** No rule to make target 'modules'. Stop.
make[1]: Leaving directory '/lib/modules/4.14.29-v7+/build'
Makefile:370: recipe for target 'modules' failed
make: *** [modules] Error 2
I guess I miss something kernel related, maybe the whole kernel source?
Any ideas anyone?
