Wifi is connected but internet is unavailable
Hi there, I freshely installed an Ubuntu Mate 22.04.1 LTS on a 2007 24inch iMac 4G Ram 250SSD and it makes it a perfect office station for internet.
But, I have an issue with Wifi card :frowning:
I have a Broadcom BCD4321 PCI card in it. I installed the Broadcom proprietary driver for BCM4321 that I found on this page : wifi_broadcom_bcm43xx [Wiki ubuntu-fr] (in french), it says it is the apt://firmware-b43-installer
When I turn on the wifi on top right panel, it finds many available wifi connection (actually way more than when the iMac was on iOS, looks like the sensibility of the wifi card is higher). I connect to my own wifi box, then first it's takes unusual long time, then when it's connected, it's not really working as firefox doesn't load pages, and everything else that use internet doesn't either.
I rebooted but it doesnt work better.
I have issue with RJ45 Lan connection too, when I switch on wifi, it stops the lan, when it switch off wifi, I have to reboot to get back lan.
It's a very weird behaviour, and I don't get what happens.
If anybody can clear my mind with few tips, you're welcome.
Thanks in advance
A few command from terminal :
lspci -nn -d 14e4:
returns
04:00.0 Network controller [0280]: Broadcom Inc. and subsidiaries BCM4321 802.11a/b/g/n [14e4:4328] (rev 03)
also,
sudo lshw -C network
returns
  *-network DÉSACTIVÉ
       description: Interface réseau sans fil
       produit: BCM4321 802.11a/b/g/n
       fabricant: Broadcom Inc. and subsidiaries
       identifiant matériel: 0
       information bus: pci@0000:04:00.0
       nom logique: wls4
       version: 03
       numéro de série: 00:**:**:**:**
       bits: 64 bits
       horloge: 33MHz
       fonctionnalités: pm msi pciexpress bus_master cap_list ethernet physical wireless
       configuration : broadcast=yes driver=wl0 driverversion=6.30.223.271 (r587334) latency=0 multicast=yes wireless=IEEE 802.11
       ressources : irq:16 mémoire:d0300000-d0303fff mémoire:d0000000-d00fffff
  *-network
       description: Ethernet interface
       produit: 88E8058 PCI-E Gigabit Ethernet Controller
       fabricant: Marvell Technology Group Ltd.
       information bus: pci@0000:05:00.0
       nom logique: ens5
       version: 13
       numéro de série: 00:**:**:**:**:**
       taille: 1Gbit/s
       capacité: 1Gbit/s
       bits: 64 bits
       horloge: 33MHz
       fonctionnalités: pm vpd msi pciexpress bus_master cap_list rom ethernet physical tp 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration : autonegotiation=on broadcast=yes driver=sky2 driverversion=1.30 duplex=full ip=192.168.1.28 latency=0 link=yes multicast=yes port=twisted pair speed=1Gbit/s
       ressources : irq:29 mémoire:d0200000-d0203fff portE/S:2000(taille=256) mémoire:d0220000-d023ffff
also ,
nmcli device
returns
DEVICE  TYPE      STATE         CONNECTION
ens5    ethernet  connecté      Connexion filaire 1
wls4    wifi      indisponible  --
lo      loopback  non-géré      --
And once it's connected in wifi
nmcli device
returns
wls4    wifi      connecté      WifiDeLaBrise
ens5    ethernet  indisponible  --
Welcome @alexandre43 to the community!
Hello !
Finally found an old usb wifi dongle lost in a drawer, plugged it in, and got wifi thru it
Thanks all
I use Ubuntu Mate on a Raspberry Pi. The thing that I've learned is that it is very fussy about its wifi. I've never manged to get a four bar signal from my workdesk....but if I move the router even slightly or if I move the Pi just slightly then the wifi indicator drops doen to two bars......and nothing here works on two bars.
Phil
Is your Pi build in a metal case ?
Does it help if you remove the case (or use a plastic case) ?
Hi....Yes, I have a metal heat sink case.
It helped when I moved the Pi nearer to the router. I now have it as far left as it will go on my desk and I have my router as close to the Pi as possible. Still, the wifi signal has to come up a flight of stairs and round the door into my office. I really ought to fit an ethernet cable but that might ruin the decor.
A metal case works like a Faraday cage. It prevents radiofrequencies to enter or leave the case. Do you have the possibility to attach an external antenna ?
My case is made from aluminium. Pi works quite well on four bars.
I just spent HOURS figuring this out, and would like to help in this area. There are conflicting drivers and sometimes even that you think you did it right it was not.
2 CONFLICTING DRIVERS: firmware-b43-installer/linux-firmware" and bcmwl-kernel-source
b43 and wl. b43 is the proprietary driver. wl is the driver that comes with linux. The page that helped me the most on WHAT driver belongs with WHAT card 14e4:43xx (ver xx)
What is not on that page which was over looked is :
**sudo apt purge dkms firmware-b43-installer AND apt purge firmware-b43-installer
THEN reboot
THEN apt install bcmwl-kernel-source
Without purging the dkms for b43 I never got the wl driver no matter if I took it off all blacklisting, and added it to modules.d manually!! Even installed i would get
/home/yourname# modprobe wl
modprobe: ERROR: could not insert 'wl': Invalid argument
on the bcm4321 with b43 driver you I was getting 10Mbps and with wl driver 100Mbps
Release 24.04.3 LTS (Noble Numbat) 64-bit Kernel Linux 6.8.0-88-generic x86_64
I'm not sure sudo apt purge dkms is needed. DKMS is used by many 'out-of-tree' drivers and isn't specific to broadcomm. Disabling that is not going to be viable for many users.
i did not purge just dkms, but dkms that dealt with the b43 installer package, for whatever reason It was in the way and it was a problem for me and wl would not load if I did not
Well, for others who look into this, maybe have a look at which packages have been installed that contain DKMS (dynamic modules). For example, I use the NVIDIA and openrazer DKMS:
user@home:~$ apt list --installed *dkms*
dkms/noble,noble,now 3.0.11-1ubuntu13 all [installed,automatic]
nvidia-dkms-550/now 550.163.01-0ubuntu0.24.04.1 amd64 [installed,local]
openrazer-driver-dkms/noble,noble,now 3.11.0~ubuntu24.04.1 all [installed,automatic]
So I wouldn't be able to purge dkms. Most of the packages that contain DKMS will have -dkms in the name, e.g. broadcomm-sta-dkms. Perhaps it was one of those that you needed to remove?
If the package doesn't get removed properly, or the (dynamic) module was installed some other way, you can probably do something nasty like go into the /usr/src folder and remove the source for the module, then run the DKMS update script which is part of initramfs-tools (I think).
And note: firmware != dkms
correct, the exact code was: apt remove broadcom-sta-dkms and I also apt purge firmware-b43-installer. I also did apt purge bcmwl-kernel-source then update-initramfs -u, update-grub, reboot. After reboot apt-get install bcmwl-kernel-source, reboot. Added wl to modules.conf. The whole point being that if I did not remove the broadcom-sta-dkms the source bcmwl driver would not load at all. not even with modprobe wl. Thank you for seeing how this could get mixed up as DKMS for other modules.
