Problem: MATE 2022.04.01 on Acer Swift 3 laptop (Model No: SF314-512) does not see/detect onboard WiFi due to missing driver.
I have read that kernel 5.17 includes "in kernel" the necessary driver. Given that, I tried from Linuxconfig.org:
How to Upgrade Ubuntu Linux Kernel
The kernel on your Ubuntu 22.04 Linux system should get upgraded along with all the other software packages you have installed. You can either use the GUI Software Updater tool, or run the following commands in terminal to upgrade the system kernel to the latest version:
$ sudo apt update $
sudo apt full-upgrade
It did not change the kernel version. Anyone have success in changing the 5.15 kernel to a later version in MATE 22.04.01?
You have shown what I suspected, ie, the upgrade only addresses the patches, not the "core" kernel. Thanks for responding and the confirmation.
After some thot, and reinstalling 22.04.1 (since the system got messed up trying other methods than the one I referred to), I am simply going to purchase a micro dongle. A Belkin dongle gives me WiFi, but the dongle extends over 3" from the case which makes it vulnerable to getting struck. And of course, the Win11 on board accesses the onboard WiFi.
See the blue circle with a T in post #3 which offers procedures that may pertain to your issue. If you click on circle it will bring up information about tkn. The @tkn is a mention.
Late reply just finished typing when @tkn posted.
@tkn - oops (how about me scrolling up), not used to how things work on this site. I am on it and will respond a little later in the day re results - I searched but never saw the links you just posted.
o.k. Bottom line is that I am going to leave things alone after reinstalling MATE. I will purchase a micro wifi USB adapter(dongle). Then hope that Mate 2024.04LTS will include a kernel which incorporates the driver needed.
I looked at the links, and realize that I had already had pursued what what was offered. After reinstalling MATE 22.04.1 to get things right again on the laptop, I went to /usr/lib/firmware and see that the the Intel posted driver files for kernels 5.1+ , 5.2+ , 5.10+ are already in /usr/lib/firmware. So no dice.
Thank you for ideas and taking an interest in the laptop Wifi problem.
Well, after stirring up the dust, problem is solved. I should have researched (googled) sooner - turns out MATE 22.10 has linux kernel 5.19. AND THAT DID THE TRICK. I simply did a reinstall over MATE 22.04.
