Wifi not working (lenovo/Realtek)
I have installed ubuntu mate 20.04 on my lenovo laptop. Wifi not working. the modem is Realtek one. its showing on the list of networks but its showing disconnected.
Hi :slight_smile:
Can you try the wireless radio key combination on your computer (like fn + F5) with hope it's only radio disabled ?
I have checked. For my system (fn + f7) combination only toggles bluetooth. it doesn't turn-on/off wifi. There is no other combinations.
arfff :confused:
Can you try this command to see the result ?
/sbin/iwlist scan
