Hello everyone.
I’m having problems connecting to the network trough wireless connection, but If I try to connect trough LAN (cable) it works fine.
Wifi shows as connected, even a bit before as the desktop fully loads itself. But when I go to the browser it says I have no internet connection, even if it the applet shows strong signal. What could be wrong?
When I plug in cable Enternet starts up, but wifi still show as connected too, is that normal?
I’m having Asus laptop and using Ubuntu MATE 16.04 with all updates and MATE 1.16.1.
info from sudo lshw -C network
*-network
description: Ethernet interface
product: RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: [email protected]:02:00.0
logical name: enp2s0
version: 10
serial: f0:79:59:31:77:75
capacity: 1Gbit/s
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress msix vpd bus_master cap_list ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl8168g-3_0.0.1 04/23/13 ip=192.168.0.12 latency=0 link=yes multicast=yes port=MII speed=1Gbit/s
resources: irq:45 ioport:e000(size=256) memory:f7904000-f7904fff memory:f7900000-f7903fff
*-network
description: Wireless interface
product: QCA9565 / AR9565 Wireless Network Adapter
vendor: Qualcomm Atheros
physical id: 0
bus info: [email protected]:03:00.0
logical name: wlp3s0
version: 01
serial: ac:b5:7d:65:02:bf
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list rom ethernet physical wireless
configuration: broadcast=yes driver=ath9k driverversion=4.4.0-67-generic firmware=N/A ip=10.42.0.1 latency=0 link=yes multicast=yes wireless=IEEE 802.11bgn
resources: irq:19 memory:f7800000-f787ffff memory:f7880000-f788ffff
I’m not very good when it comes to that much technical stuff to know what those things means trough, so any help would be welcomed, please.
