first of all thank you for the quick response really helps a noob, truly.
second you presume correctly I am using xrdp which I am proud to say I started using systemctl
noobs are easily pleased!!!
Thirdly thanks so much for the pointer about typing kodi into a terminal. I am so used to icons I completely forgot that could be done, what a dullard !
SO it dumped out with the errors below AND a pointer to a log file which is below the “++++” I will look at it tomorrow BUT if you or anyone else can shed some light onto what is going on here I would be most grateful. I also found some other diagnostic info that might help you help me
it’s below the “%%%%%%%%%%%%%%%%%”
thanks again Lah7 you are great
kodi
libGL error: No matching fbConfigs or visuals
found
libGL error: failed to load driver: swrast
ERROR: Unable to create
GUI. Exiting
Segmentation fault (core dumped)
Crash report available at
/home/dave/kodi_crashlog-20151215_182247.log
CRASH LOG
CONTAINS
dave@tvattic:~$ cat
############## Kodi CRASH LOG
################ SYSTEM INFO ################
Date:
Tue Dec 15 18:22:47 CST 2015
Kodi Options:
Arch: x86_64
Kernel:
Linux 4.2.0-19-generic #23-Ubuntu SMP Wed Nov 11 11:39:30 UTC 2015
Release:
Ubuntu 15.10 (Wily Werewolf)
############## END SYSTEM INFO
############### STACK TRACE #################
gdb not
installed, can’t get stack trace.
############# END STACK TRACE
################# LOG FILE
18:22:35 T:139985586874560 NOTICE: special://profile/
is mapped to:
special://masterprofile/
NOTICE:
18:22:35
T:139985586874560 NOTICE: Starting Kodi from Debian (15.1 Git:
(unknown)).
Platform: Linux x86 64-bit
18:22:35 T:139985586874560 NOTICE: Using Debug
Kodi from Debian x64 build
18:22:35 T:139985586874560 NOTICE: Kodi from
Debian compiled from
15.1+dfsg1-3 by GCC 5.2.1 for Linux x86 64-bit version
4.1.3 (262403)
18:22:35 T:139985586874560 NOTICE: Running on Ubuntu 15.10,
kernel:
Linux x86 64-bit version 4.2.0-19-generic
18:22:35
T:139985586874560 NOTICE: FFmpeg version: 2.7.2-1build1
18:22:35
T:139985586874560 NOTICE: Host CPU: Intel® Pentium® D CPU
3.40GHz, 2
cores available
18:22:35 T:139985586874560 NOTICE: special://xbmc/ is mapped
to:
/usr/share/kodi
special://xbmcbin/ is mapped to:
/usr/lib/kodi
18:22:35
T:139985586874560 NOTICE: special://masterprofile/ is mapped
to:
/home/dave/.kodi/userdata
18:22:35 T:139985586874560 NOTICE: special://home/
is mapped to:
/home/dave/.kodi
special://temp/ is mapped to:
/home/dave/.kodi/temp
18:22:35
T:139985586874560 NOTICE: The executable running is:
/usr/lib/kodi/kodi.bin
18:22:35 T:139985586874560 NOTICE: Local
hostname: tvattic
18:22:35 T:139985586874560 NOTICE: Log File is located:
/home/dave/.kodi/temp/kodi.log
18:22:36
T:139985586874560 DEBUG: ConsoleKit.Manager:
org.freedesktop.DBus.Error.ServiceUnknown - The name
org.freedesktop.ConsoleKit was not provided by any .service
files
18:22:36 T:139985586874560 DEBUG: Previous line repeats 1
times.
18:22:36 T:139985586874560 DEBUG: DeviceKit.Power:
org.freedesktop.DeviceKit.Disks was not provided by any .service
files
18:22:36 T:139985586874560 INFO: Selected Logind/UPower as
PowerSyscall
18:22:36 T:139985586874560 DEBUG: LogindUPowerSyscall -
inhibit lock
taken, fd 11
18:22:36 T:139985586874560 ERROR: DBus: Error
org.freedesktop.DBus.Error.InvalidArgs - No such property
OnLowBattery
18:22:36 T:139985586874560 INFO: Selected UPower as
PowerSyscall
CanSuspend
CanHibernate
18:22:36 T:139985586874560 NOTICE: load settings…
18:22:36
T:139985586874560 DEBUG: CSettings: loaded settings
definition from
special://xbmc/system/settings/settings.xml
definition from
special://xbmc/system/settings/linux.xml
PulseAudio: Context authorizing
PulseAudio: Context setting name
PulseAudio: Context ready
18:22:36 T:139984891873024 DEBUG: PulseAudio:
Found Cedar HDMI Audio
[Radeon HD 5400/6300 Series] Digital Stereo (HDMI)
with devicestring
alsa_output.pci-0000_01_00.1.hdmi-stereo
18:22:36
T:139984891873024 DEBUG: PulseAudio: Found Built-in Audio
Analog Stereo
with devicestring alsa_output.pci-0000_00_1b.0.analog-stereo
18:22:36
T:139985586874560 NOTICE: Found 1 Lists of Devices
18:22:36
T:139985586874560 NOTICE: Enumerated PULSE devices:
18:22:36
T:139985586874560 NOTICE: Device 1
NOTICE: m_deviceName : Default
NOTICE: m_displayName : Default
NOTICE: m_displayNameExtra: Default
Output Device
(PULSEAUDIO)
18:22:36 T:139985586874560 NOTICE: m_deviceType :
AE_DEVTYPE_PCM
m_channels : FL,FR
m_sampleRates :
5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000,384000
18:22:36
T:139985586874560 NOTICE: m_dataFormats :
AE_FMT_U8,AE_FMT_S16NE,AE_FMT_S24NE3,AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_FLOAT
18:22:36
T:139985586874560 NOTICE: Device 2
NOTICE: m_displayName : Cedar
HDMI Audio [Radeon HD 5400/6300
m_displayNameExtra: HDMI /
DisplayPort (PULSEAUDIO)
18:22:36
AE_DEVTYPE_PCM
m_channels : FL,FR
m_sampleRates :
18:22:36
18:22:36
T:139985586874560 NOTICE: Device 3
NOTICE: m_displayName : Built-in
Audio Analog Stereo
18:22:36
T:139985586874560 NOTICE: m_displayNameExtra: Speakers
(PULSEAUDIO)
m_deviceType :
AE_DEVTYPE_PCM
NOTICE: m_channels : FL,FR
NOTICE: m_sampleRates :
18:22:36
18:22:36
T:139985586874560 NOTICE: No settings file to load
(special://xbmc/system/advancedsettings.xml)
NOTICE: Loaded settings file from
special://profile/advancedsettings.xml
NOTICE: Contents of
are…
0
45
3
0
true
18:22:36
T:139985586874560 NOTICE: Default DVD Player: dvdplayer
18:22:36
T:139985586874560 NOTICE: Default Video Player: dvdplayer
18:22:36
T:139985586874560 NOTICE: Default Audio Player: paplayer
18:22:36
T:139985586874560 NOTICE: Disabled debug logging due to GUI
setting. Level
0.
18:22:36 T:139985586874560 NOTICE: Log level changed to
"LOG_LEVEL_NORMAL"
18:22:36 T:139985586874560 NOTICE: CMediaSourceSettings:
loading media
sources from special://masterprofile/sources.xml
18:22:36
T:139985586874560 NOTICE: Loading player core factory settings
from
special://xbmc/system/playercorefactory.xml.
DEBUG: CPlayerCoreConfig::: created
player DVDPlayer for core
1
18:22:36 T:139985586874560 DEBUG: CPlayerCoreConfig:::
created
player oldmplayercore for core 1
player PAPlayer for core
3
18:22:36 T:139985586874560 DEBUG: CPlayerSelectionRule::Initialize:
creating rule: system rules
creating rule:
hdhomerun/mms/udp
creating rule: lastfm/shout
18:22:36
creating rule:
rtmp
creating rule: rtsp
creating rule: streams
18:22:36
creating rule:
aacp/sdp
creating rule: mp2
18:22:36
creating rule:
dvd
creating rule: dvdimage
creating rule: sdp/asf
18:22:36
creating rule:
nsv
creating rule: radio
18:22:36 T:139985586874560 NOTICE: Loaded
playercorefactory configuration
18:22:36 T:139985586874560 NOTICE: Loading
from
special://masterprofile/playercorefactory.xml.
NOTICE:
special://masterprofile/playercorefactory.xml does not exist.
Skipping.
18:22:36 T:139985586874560 INFO: creating
subdirectories
18:22:36 T:139985586874560 INFO: userdata folder:
18:22:36 T:139985586874560 INFO: recording
folder:
18:22:36 T:139985586874560 INFO: screenshots folder:
18:22:36
T:139984891873024 NOTICE: Thread ActiveAE start, auto delete:
false
18:22:36 T:139984958985984 NOTICE: Thread AESink start, auto
delete: false
18:22:36 T:139984958985984 INFO: CActiveAESink::OpenSink -
initialize
sink
18:22:36 T:139984958985984 DEBUG:
CActiveAESink::OpenSink - trying to
open device PULSE:Default
18:22:36
T:139984958985984 DEBUG: PulseAudio: Context authorizing
18:22:36
T:139984958985984 DEBUG: PulseAudio: Context setting name
18:22:36
T:139984958985984 DEBUG: PulseAudio: Context ready
18:22:36
T:139984958985984 DEBUG: PulseAudio: Stream ready
18:22:36
T:139984958985984 NOTICE: PulseAudio: Opened device Default in
pcm mode
with Buffersize 150 ms
CActiveAESink::OpenSink - PULSE
Initialized:
DEBUG: Output Device : Default
18:22:36 T:139984958985984 DEBUG: Sample
Rate : 44100
18:22:36 T:139984958985984 DEBUG: Sample Format :
AE_FMT_FLOAT
18:22:36 T:139984958985984 DEBUG: Channel Count :
2
18:22:36 T:139984958985984 DEBUG: Channel Layout: FL,FR
18:22:36
T:139984958985984 DEBUG: Frames : 2205
18:22:36
T:139984958985984 DEBUG: Frame Samples : 4410
18:22:36
T:139984958985984 DEBUG: Frame Size : 8
NOTICE: Running database version Addons19
SECTION:LoadDLL(special://xbmcbin/system/libcpluff-x86_64-linux.so)
18:22:36
T:139985586874560 DEBUG: Loading:
/usr/lib/kodi/system/libcpluff-x86_64-linux.so
18:22:38
T:139985586874560 INFO: ADDON: cpluff: ‘Could not read
plug-in directory
/usr/lib/kodi/addons: No such file or directory’
18:22:38 T:139985586874560
NOTICE: ADDONS: Using repository
repository.xbmc.org
18:22:38
T:139985586874560 NOTICE: ADDONS: Using repository
repository.tknorris.release
18:22:38 T:139985586874560 NOTICE: ADDONS:
Using repository
repository.lambda
repository.Kinkin
repository.eldorado
18:22:38
repository.xbmchub
18:22:38 T:139985586874560 NOTICE: ADDONS: Using
repository
repository.Rodrigo
Using repository
repository.entertainmentrepo
repository.BlazeRepo
18:22:38
repository.eleazar
repository
repository.dudehere.plugins
repository.metalkettle
18:22:38
T:139985586874560 DEBUG: LoadMappings - loaded node “Motorola
Nyxboard
Hybrid”
18:22:38 T:139985586874560 DEBUG: LoadMappings - loaded node “CEC
Adapter”
“Pulse-Eight CEC Adapter”
LoadMappings - loaded node “iMON HID
device”
DEBUG: CPeripheralBusUSB - initialised udev
monitor
18:22:38
T:139985586874560 DEBUG: SECTION:LoadDLL(libcec.so.3)
18:22:38
T:139985586874560 DEBUG: Loading: libcec.so.3
18:22:38 T:139984922519296
NOTICE: Thread PeripBusCEC start, auto
delete: false
18:22:38
T:139984914126592 NOTICE: Thread PeripBusUSBUdev start, auto
delete:
false
18:22:38 T:139984905733888 NOTICE: Thread RemoteControl start, auto
delete: false
18:22:38 T:139985586874560 INFO: CKeyboardLayoutManager:
loading
keyboard layouts from
special://xbmc/system/keyboardlayouts…
18:22:38 T:139984905733888 INFO:
LIRC Process: using: /dev/lircd
18:22:38 T:139984905733888 INFO: LIRC
Connect: connect failed: No
18:22:38
T:139984905733888 INFO: CRemoteControl::Process - failed to
connect to
LIRC, will keep retrying every 5 seconds
CKeyboardLayoutManager: keyboard
layout “Polish QWERTY” successfully
loaded
18:22:38 T:139985586874560 DEBUG: CKeyboardLayoutManager: keyboard
layout “Norwegian QWERTY” successfully loaded
18:22:38
layout
“Ukrainian ЙЦУКЕН” successfully loaded
layout “Ukrainian АБВ” successfully
loaded
layout “Portuguese (Portugal) QWERTY” successfully loaded
18:22:38
layout
“Hungarian QWERTZ” successfully loaded
layout “Bulgarian ЯВЕРТЪ” successfully
loaded
layout “Bulgarian АБВ” successfully loaded
layout “Swedish QWERTY” successfully
loaded
layout “Lithuanian AZERTY” successfully loaded
18:22:38
layout
“Lithuanian QWERTY” successfully loaded
layout “English QWERTY” successfully
loaded
layout “English AZERTY” successfully loaded
layout “English ABC” successfully
loaded
layout “Hebrew QWERTY” successfully loaded
layout “Hebrew ABC” successfully
loaded
layout “Spanish QWERTY” successfully loaded
layout “Greek QWERTY” successfully
loaded
layout “Arabic QWERTY” successfully loaded
layout “Danish QWERTY” successfully
loaded
layout “Turkish QWERTY” successfully loaded
layout “German QWERTZ” successfully
loaded
layout “Romanian QWERTY” successfully loaded
layout “Russian ЙЦУКЕН” successfully
loaded
layout “Russian АБВ” successfully loaded
DEBUG: UDisks:
org.freedesktop.UDisks was not provided by any .service files
18:22:38
T:139985586874560 DEBUG: DeviceKit.Disks:
files
18:22:38 T:139985586874560 DEBUG: Selected UDev as storage
provider
18:22:38 T:139985586874560 NOTICE: Setup SDL
18:22:38
T:139985586874560 ERROR: CXRandR::Query - unable to open
xrandr
xml
18:22:38 T:139985586874560 INFO: Available videomodes
(xrandr):
18:22:38 T:139985586874560 NOTICE: Checking resolution
16
18:22:38 T:139985586874560 ERROR: Failed to find matching
visual
18:22:38 T:139985586874560 INFO: GL: Maximum texture width:
32768
18:22:38 T:139985586874560 DEBUG: GLX_EXTENSIONS:
GLX_ARB_get_proc_address GLX_EXT_import_context GLX_EXT_visual_info
GLX_EXT_visual_rating GLX_MESA_multithread_makecurrent
18:22:38
T:139985586874560 ERROR: InitRenderSystem() glewInit returned
1: Missing
GL version
18:22:38 T:139985586874560 FATAL: CApplication::Create: Unable
to init
rendering system
18:22:39 T:139985586874560 DEBUG: PVRManager -
destroyed
18:22:39 T:139984905733888 DEBUG: Failed to connect to LIRC.
Giving up.
############### END LOG FILE
############ END Kodi CRASH LOG
i also found a possible diagnostic sequence that might help you help me.
dave@tvattic:~$ sudo find /usr -iname “libGL.so” -exec ls -l {}
[sudo] password for dave:
lrwxrwxrwx 1 root root 14 Oct 9 00:16
/usr/lib/x86_64-linux-gnu/mesa/libGL.so.1 -> libGL.so.1.2.0
-rw-r–r--
1 root root 619000 Oct 9 00:16
/usr/lib/x86_64-linux-gnu/mesa/libGL.so.1.2.0
Oct 9 00:14
/usr/lib/i386-linux-gnu/mesa/libGL.so.1 ->
libGL.so.1.2.0
-rw-r–r-- 1 root root 689788 Oct 9 00:14
/usr/lib/i386-linux-gnu/mesa/libGL.so.1.2.0
dave@tvattic:~$ export
LIBGL_DEBUG=verbose
dave@tvattic:~$ glxgears
libGL: OpenDriver: trying
/usr/lib/x86_64-linux-gnu/dri/tls/swrast_dri.so
/usr/lib/x86_64-linux-gnu/dri/swrast_dri.so
libGL: Can’t open configuration
file /home/dave/.drirc: No such file or
directory.
libGL: Can’t open
configuration file /home/dave/.drirc: No such file or
directory.
libGL
error: No matching fbConfigs or visuals found
driver: swrast
20297 frames in 5.0 seconds = 4059.103 FPS
20840 frames in
5.0 seconds = 4164.935 FPS
20840 frames in 5.0 seconds = 4166.469
FPS
19340 frames in 5.0 seconds = 3864.388 FPS
20020 frames in 5.0 seconds
= 4002.496 FPS
23160 frames in 5.0 seconds = 4630.702 FPS
22840 frames in
5.0 seconds = 4564.828 FPS
^C
