Window adjust "grab-zone" size - Issues
Hi @vkareh,
Is there a way to force a full rebuild? I scanned thru the Makefile, but I don't see anything I recognize as a flag to force that. Could you give me the command format to make that happen?
All I'm getting are messages like these:
make[2]: Entering directory '/DB001_F2/home/Downloads/MateThemes/mate-themes-3.22.26/desktop-themes/BlackMATE-border'
Making all in metacity-1
make[3]: Entering directory '/DB001_F2/home/Downloads/MateThemes/mate-themes-3.22.26/desktop-themes/BlackMATE-border/metacity-1'
make[3]: Nothing to be done for 'all'.
make[3]: Leaving directory '/DB001_F2/home/Downloads/MateThemes/mate-themes-3.22.26/desktop-themes/BlackMATE-border/metacity-1'
make[3]: Entering directory '/DB001_F2/home/Downloads/MateThemes/mate-themes-3.22.26/desktop-themes/BlackMATE-border'
make[3]: Nothing to be done for 'all-am'.
make[3]: Leaving directory '/DB001_F2/home/Downloads/MateThemes/mate-themes-3.22.26/desktop-themes/BlackMATE-border'
make[2]: Leaving directory '/DB001_F2/home/Downloads/MateThemes/mate-themes-3.22.26/desktop-themes/BlackMATE-border'
------- edit --------
And I just now understood what you meant, about only for maximized windows. I can confirm that behaviour as observed. My darker image is used for the maximized condition.
As a comment, that seems a bit of a restrictive (and not-helpful) pre-condition. :frowning:
------- edit 2 --------
I made the following changes,
root@OasisMega1:/DB001_F2/home/Downloads/MateThemes/mate-themes-3.22.26/desktop-themes/BlackMATE-border/metacity-1# diff metacity-theme-3.DISTRO.xml metacity-theme-3.xml
208a209,220
> <!-- START of innsert -->
> <draw_ops name="rounded_titlebar_unfocused">
> 	<include name="titlebar_fill_unfocused" />
> </draw_ops>
> <draw_ops name="rounded_titlebar_unfocused_alt2">
> 	<include name="titlebar_fill_unfocused_alt2" />
> </draw_ops>
> <!-- END of innsert -->
967a980,981
> 	<piece position="titlebar" draw_ops="titlebar_fill_unfocused" />
968a983
and "rebuilt" the MATE Themes, and the BlackMATE-border does show the darker titlebar for non-maximized windows. :slight_smile:
--------- edit 3 -----------
Issue submitted on GitHub, asking to update the Theme as per the observed oversight.
--- metacity-theme-3.DISTRO.xml	2024-04-08 20:41:47.000000000 -0400
+++ metacity-theme-3.xml	2024-08-16 16:33:40.363183333 -0400
@@ -206,6 +206,18 @@
 	<include name="titlebar_fill_focused_alt" />
 </draw_ops>
+<!-- START of insert -->
+<draw_ops name="rounded_titlebar_unfocused">
+	<include name="titlebar_fill_unfocused" />
+</draw_ops>
+<draw_ops name="rounded_titlebar_unfocused_alt2">
+	<include name="titlebar_fill_unfocused_alt2" />
+</draw_ops>
+<!-- END of insert -->
 <draw_ops name="border_focused">
 	<rectangle color="C_border_focused" x="0" y="0" width="width-1" height="height-1" filled="false" />
 </draw_ops>
@@ -965,7 +977,10 @@
 <frame_style name="normal_unfocused" geometry="normal_unfocused">
 	<piece position="entire_background" draw_ops="entire_background_unfocused" />
+	<piece position="titlebar" draw_ops="titlebar_fill_unfocused" />
 	<piece position="titlebar" draw_ops="rounded_titlebar_focused" />
 	<piece position="title" draw_ops="title_unfocused" />
 	<piece position="overlay" draw_ops="rounded_border_unfocused" />
 	<button function="close" state="normal" draw_ops="close_unfocused"/>
---------- edit 4 ---------
Bug report #2077202 submitted on launchpad.
If you've found this discussion of interest, or helpful, and want to pursue your own customization of the MATE Themes, you might be interested in looking at this other post, where the lessons learned about the build process have been compiled into a "workflow script" to help keep things structured in a manner that "helps" the individual to customize his Desktop.
