Since I upgraded about a week ago to 20.04, I switched to Mate rather than Gnome as flashback doesn't work very well any more. I can see several advantages to mint, but it is taking me time to get used to it.
One problem I've had over the past couple of days is something that has changed without me being aware of doing anything. The boarders have become extremely narrow. I understand not seeing them in full screen mode, but it makes adjusting / resizing them in window mode almost impossible unless you significantly lower your mouse sensitivity. The only place it can easily be done is the wide bar at the top of windows. The boarder line is literally just 1 pixel thick. Something doesn't seem right to me.
Here is an image:
As I can't upload two, I merged them together and took another print screen. This is just showing several windows. The terminal and the toolbox in GIMP image editor (which is an adjustable window).
The boarders seem so narrow that in gimp, you can barely see it as a window. And with every application, you need to line the very tip of your cursor arrow in line with the 1 pixel wide boarder to adjust it, or it isn't possible.
I'm really not sure what has happened here, but it certainly wasn't like this when I first upgraded, so I must have triggered it, or something unexpected changed it.
The things that I'm aware of changing relating to the interface in the theme in the control centre since the upgrade and resizing the top and bottom panel. But this was well before this issue occurred and it doesn't seem at all related.
Any advice?
