Hi All
I have a dual boot system. UM (16.10) and Windows 10 and I have recently started using a wireless keyboard and mouse. Both work perfectly once I am logged in, however, I needed to log into Windows earlier today and realised that the keyboard is not active at the point when GRUB menu is on the screen. This isn’t normally a problem as 99% of the time I use UM, but on this occasion I had to plug in a wired keyboard to get into Windows.
Like I say, once GRUB has auto selected my first choice (UM) it works fine at the login screen.
Do you know if there is anything I can do to help GRUB detect the wireless devices? I have a mini USB receiver plugged into a USB hub for the keyboard and mouse. I read in some other discussions that were generally about wireless devices, that there may be BIOS setting to change, but I’ve taken a look and could not find anything relevant.
Is it simply a timing issue? Can you delay the GRUB menu in a config file maybe so it doesn’t appear until after wireless devices have been detected?
Any suggestions would be great.
Cheers,
Martin
