Workaround for menu editor (mozo) crashes in 26.04
For all those who are testing UM26.04:
Because 26.04 is still in alpha, there are still a few wrinkles that have to be ironed out.
You might have noticed that the menu editor (mozo) is (for some users anyway) unusable at the moment because severe crashes.
For the moment you can solve this by removing mozo and installing menulibre:
sudo apt purge mozo
sudo apt install menulibre
Happy testing ! :slight_smile:
I've always preferred menulibre over mozo anyway,I like it's interface much better.
Yes, I just discovered why you prefer it. It is much more versatile and much less crash prone :grinning_face_with_smiling_eyes:
I've been usingmenulibre since 18.04 after mozo caused a whole host of issues with the Applications menu to which I was never able to rectify.
To bad it's not the default as it really is much better.
