HI Team.
I'm getting the following message on a recently installed system:
[email protected]:~$ sudo apt-get upgrade
[sudo] password for r4:
Reading package lists... Done
Building dependency tree... Done
Calculating upgrade... Done
The following packages were automatically installed and are no longer required:
chromium-codecs-ffmpeg-extra gstreamer1.0-vaapi libatomic1:i386 libbsd0:i386
libdrm-amdgpu1:i386 libdrm-nouveau2:i386 libdrm-radeon1:i386 libdrm2:i386
libedit2:i386 libelf1:i386 libexpat1:i386 libffi8:i386 libglvnd0:i386
libgstreamer-plugins-bad1.0-0 libicu70:i386 libllvm13:i386 libmd0:i386
libnvidia-cfg1-470 libnvidia-common-470 libnvidia-compute-470:i386
libnvidia-decode-470 libnvidia-decode-470:i386 libnvidia-egl-wayland1
libnvidia-encode-470 libnvidia-encode-470:i386 libnvidia-extra-470
libnvidia-fbc1-470 libnvidia-gl-470 libnvidia-gl-470:i386 libnvidia-ifr1-470
libsensors5:i386 libstdc++6:i386 libvulkan1:i386 libwayland-client0:i386
libx11-6:i386 libx11-xcb1:i386 libxau6:i386 libxcb-dri2-0:i386
libxcb-dri3-0:i386 libxcb-glx0:i386 libxcb-present0:i386 libxcb-randr0:i386
libxcb-shm0:i386 libxcb-sync1:i386 libxcb-xfixes0:i386 libxcb1:i386
libxdmcp6:i386 libxext6:i386 libxfixes3:i386 libxml2:i386 libxnvctrl0
libxshmfence1:i386 libxxf86vm1:i386 mesa-vulkan-drivers:i386
nvidia-compute-utils-470 nvidia-kernel-source-470 nvidia-settings
nvidia-utils-470 pkg-config screen-resolution-extra
xserver-xorg-video-nvidia-470
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Problem I see is that it says nvidia drivers, mesa vulkan and a lot of gstreamer things. How can I make sure that future updates will ignore this?
