Hello everyone,
i have tried to burn a bluray with brasero and it always crashed, fortunatly before wasting a bluray.
Then i’ve tried xfburn and it worked perfectly.
So i write this to think about changing brasero with xfburn.
Hello everyone,
Hi @francesco,
did you set the burn speed to the lowest setting?.
I too have had burn fails with Brasero and I use K3B myself!.
K3b is the “Roll Royce” of burners, but pulls in a bunch of KDE packages. Xfburn seems to always get the job done without any of the bloat. I like them both.
Thank you @wolfman, i don’t remember unfortunatly and i don’t have anymore a spare bluray to try, but i think the problem is that brasero has problems with bluray.
k3b doesn’t integrate that well and the last version is from 2014. Xfburn seems to me a good choice, the only thing i miss would be multi-volume backup.
When i need to burn a lot of data to multiple bds, i copy everything in a dir (let’s call it RootDir) and i use:
dirsplit -s 23500000K -e2 RootDir
genisoimage -D -r --joliet-long -graft-points -path-list vol_1.list -o
immagine1.iso
And i repeat for vol_n.list creating immaginen.iso
And after i burn iso’s them (i used xfburn also in the past, when i used to use lubuntu).
I believe it is maintained.
I cannot report any bad burns or problems with K3B, although as pointed out it brings in lots of bloat, it is still a good app!.
Hallo wolfman
I moved away from brasero to k3b when I was still running Ubuntu Unity. Brasero and gedit just didn’t work for me, so I use k3b and kate.
Thank you all the developers who have with years of continuous work made such a thing (freedom of choice) possible.
Will k3b make a live OS on a thumb drive? Brasero will not even recognize the drive although it shows up on my desktop.
Thanks for any help you may be able to give.
Will Xfburn make a live OS on a thumb drive? Brasero will not even recognize the drive although it shows up on my desktop.Thanks for any help you may be able to give.
Hallo
Take a look at these two postings:
Wimpy recomends gnome-disks:
https://ubuntu-mate.community/t/why-is-gnome-disks-replacing-gparted/3127
How to create a live-system USB:
http://ubuntu-mate.org/how-to-create-bootable-usb-drive/
Has that helped?
Sorry but not really. What I am trying to do is get a live usb of an OS from an iso that is in my download folder. xfburn and brasero can’t see my usb disc but I have just found that unetbootin does see my usb disc. I have used brasero before and had no problems.
Thanks to the posts from others, I installed xfburn and it works a treat. . . Strange that brasero doesn't work on any machine I've installed it on. Maybe Ubuntu mate developers should switch to an alternative in future releases. Happy days anyway . . . Mate rocks as always
that's what i wrote in 2016. I hope devs will really consider xfburn instead of brasero.
Sadly xfburn development seems to be dead and it wasn't ported to gtk3.
I also use K3B. I don't worry alot about KDE packages as I also install Kpat, Krita and now and then some other KDE packages. Most of these share some of the same libraries.
Xfburn's last update is 0.5.5 , released on 2017-12-14
The good news is that it is not listed on the unmaintained or deprecated projects from the 4.14 Xfce release notes.
Seems like xfburn is being ported to gtk 3:
