Open a terminal and enter:
xman
xman
How bout a calendar (in terminal)
cal
Wow, tough crowd. Ok, what about a terminal calculator?
Code:
python
Lol, if you want to play this game, how about:
xeyes
What would you need the most if you was stuck in a bare X environment?
xterm
Of course
Appropriate answer
whatis linux
sudo apt install pacman4console
In terminal:
pacman4console
and game away
Have a terminal command that you like to use again, but can’t remember the exact command? You can look it up with…
Code:
history
StarWars anyone…
Code:
telnet towel.blinkenlights.nl
Open a terminal and enter :
sudo visudo
That takes you to a terminal text editor (Nano). You then need to add the below line right under the other “Defaults” settings:
Defaults insults
Then save Ctrl + o and close Ctrl + x
Now next time you enter the wrong password the reply will surprise you
On a side note you must navagiate Nano using the arrow keys unless you activate the mouse control:
Alt + m
And last, about visudo (in terminal):
man visudo
