if i have my window manager set to marco, i can use xrandr and setup my screen resolution with no problems, than i can switch to compiz and everything is fine with the new resolution i have set.
But if i have my window manager set to compiz and i do the xrandr command to set my resolution my desktop goes all wacko with distorted colors and i can’t do nothing.
i made a script and added it to startup programs to automatically set my resolution when the computer boots up. and everything is fine if i’m using marco as my window manager. but video’s have a screen tearing effect when i use marco.
so so far the only way i can run compiz with my set resolution is to first load carco, run xrandr and set my resolution then go back and select compiz.
i am a noob to linux so does anyone have a way or script i can run to fix this problem and have it boot up with my resolution settings and compiz without crashing the desktop?
I am running ubuntu mate 15.04 and my video card is asus eah4850/1gb
