Zoom B1 Four bass interface
Howdy.
I have succesfully installed "ToneLib Zoom" and i can use my interface via it. Interface is connected to my desktop via usb. I can adjust sound and play it from stereos what are connected to the interface directly.
How ever, i cant get sound via usb to computer (to Reaper DAW). I have installed Jack etc. but when i try to find any sound input via USB, my OS wont offer anything.
Afaik: Zoom has not official support for Linux | ZOOM
However, it is a basic usb interface so i wondered can i get the sound some other way. I never installed Zoom software on windows either. I just installed Asio and Reaper and all was good to go. Any chance to do so with Mate?
[edit]
lsusb
does see the interface:
Bus 001 Device 003: ID 1686:04a1 ZOOM Corporation ZOOM G Series
[/edit]
Welcome @Ek_Bass to the community!
Thanks Bombilla.
I clear out here, that it is possible to use this Zoom via usb. With windows it only needs Asio to be installed and i could use it with Reaper.
Now im bit lost here, havent used linux since 2008.
