Hi everyone,
I can't install zoom program,
I downloaded the package from the website zoom.us , but I have the following:
I wrote at /Downloads$ sudo apt install ./zoom_amd64.deb
Reading package lists... Done
Building dependency tree
Note, selecting 'zoom:amd64' instead of './zoom_amd64.deb'
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
zoom:amd64 : Depends: libxcb-keysyms1:amd64 but it is not installable
Depends: libglib2.0-0:amd64 but it is not installable
Depends: libxcb-shape0:amd64 but it is not installable
Depends: libxcb-shm0:amd64 but it is not installable
Depends: libxcb-xfixes0:amd64 but it is not installable
Depends: libxcb-randr0:amd64 but it is not installable
Depends: libxcb-image0:amd64 but it is not installable
Depends: libfontconfig1:amd64 but it is not installable
Depends: libgl1-mesa-glx:amd64 but it is not installable
Depends: libegl1-mesa:amd64 but it is not installable
Depends: libxi6:amd64 but it is not installable
Depends: libsm6:amd64 but it is not installable
Depends: libxrender1:amd64 but it is not installable
Depends: libpulse0:amd64 but it is not installable
Depends: libxcomposite1:amd64 but it is not installable
Depends: libxslt1.1:amd64 but it is not installable
Depends: libsqlite3-0:amd64 but it is not installable
Depends: libxcb-xtest0:amd64 but it is not installable
Depends: libdbus-1-3:amd64 but it is not installable
Depends: libxtst6:amd64 but it is not installable
Depends: libxcb-xinerama0:amd64 but it is not installable
Depends: libxkbcommon-x11-0:amd64 but it is not installable
Depends: libfreetype6:amd64 (>= 2.6) but it is not installable
Can any one help please?
Many thanks
Maha
