Is it possible to install zoom on one of these running UbuntuMate 20.04?
I can see there is a zoom_amd64.deb but haven't any further knowledge
Derek
that package would not work as it is for intel/amd processors it would have to say arm64 and then it should work provided the pi has enough resources to run it
Zoom does not currently offer their software with an arm version.
That accords with what I have found - I hoped for a solution.
Derek
Search youtube - there is a video showing how to get zoom running on Pi with something called (I think) box86. It seems to be "good enough" to use. It's on my ever-growing list of things to try...
The thing I haven't yet been able to find is a Discord instance - real pita
Found the link - there are several others too: https://www.youtube.com/watch?v=9yx3XzYnHV4
