I installed UM and it is not able to boot to the desktop.
I burned it at default settings. The live dvd ran fine.
edit:
I have able to get to the Desktop.
This seems to be in the area of fsck.
I re-burned the DVD at 6X and it shows the same error lvmetad. It does a direct activation and goes to the Desktop.
I will update it soon from the Welcome screen.
After updating through the Welcome screen, I rebooted and had the same error that direct activation was used.
Then fsck did its job and it booted to Desktop.
I did get a update prompt that I selected to “remind me later”
I will run that tonight.
Are you, by any chance, dual-booting with Windows 8 or 10?
No. One HDD and two ODD.
I wonder if I should have chosen not to use LVM.
I posted my machine specs. in the Super List.
Check if this can help you: http://unix.stackexchange.com/questions/270388/lvmetad-is-not-active-yet-using-direct-activation-during-sysinit
I am not for sure how that helps.
edit:
I may have to get rid of my logical volumes.
Check out the partition guide and before you do too much on the system, re-format everything using 1 swap, 1 root and 1 home partitions!. ![]()
don't use LVM
create your partitions per the guide
wipe the drive completley and do the following:
set up a swap partiton of the same size as your RAM
create an "Extended partition" with the remainder of the drive
create a root partition of not more than 15GB
use the rest for your home partition.
Install using the "Something Else method":
I used to do this during the Red Hat days.
I am not for sure how I want to do it now.
It will be a while before I do this.
I may rerun the installer minus the LVM settings.
I reinstalled using default settings and did not use LVM and I did not get the error as above.
I am running Mutiny and Marco ( Compton GPU Compositor ).
The machine rebooted after a reboot and now is running.
It appears to be running fine.
Was that normal?
Hi. I installed Ubuntu MATE 16.04 over an existing 14.04 unity install, with LVM, dm-crypt and a raid5 stacked on one another. I saw this exact screen. A few reboots and some tweaks later, I managed to fix it. One of the steps I do believe was crucial to this repair was rebuilding the initramfs.
Lots of things break when you have goofy setups like mine.
This sounds like you basically had a broken install so yes!, it would be normal for things to improve after re-installing!. ![]()
You can tick best answer to mark this thread as solved so it helps others!. ![]()
