VMware Workstation/Player will fail to build kernel modules VMMON & VMNET
Newer kernel versions have issues with building kernel modules VMMON and VMNET. This will/can occur with the 5.4.x kernel series that are included in the 20.04 Focal Fossa release.
Below is a work-around for this issue derived from the great work being maintained by Michael Kubecek.
You will need to download the appropriate file based on what version you have installed, this example is based on 15.5.1
Download the replacement files:
wget https://github.com/mkubecek/vmware-host-modules/archive/workstation-15.5.1.tar.gz
Extract the files:
tar -xzf workstation-15.5.1.tar.gz
cd into directory:
cd vmware-host-modules-workstation-15.5.1/
Create tar files of the modules:
tar -cf vmmon.tar vmmon-only
tar -cf vmnet.tar vmnet-only
Copy files to /usr/lib/vmware.modules.source (elevated privileges needed):
sudo cp -v vmmon.tar vmnet.tar /usr/lib/vmware/modules/source/
Install modules (elevated privileges needed):
sudo vmware-modconfig --console --install-all
You should get an output similar to the following:
Stopping VMware services:
VMware Authentication Daemon done
VM communication interface socket family done
Virtual machine communication interface done
Virtual machine monitor done
Blocking file system done
make: Entering directory '/tmp/modconfig-ySDgLm/vmmon-only'
Using kernel build system.
/usr/bin/make -C /lib/modules/5.4.0-14-generic/build/include/.. M=$PWD SRCROOT=$PWD/. \
MODULEBUILDDIR= modules
make[1]: Entering directory '/usr/src/linux-headers-5.4.0-14-generic'
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/linux/driver.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/linux/hostif.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/linux/driverLog.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/common/memtrack.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/common/apic.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/common/statVarsVmmon.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/common/vmx86.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/common/sharedAreaVmmon.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/common/cpuid.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/common/task.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/common/comport.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/common/phystrack.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/vmcore/moduleloop.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/bootstrap/monLoaderVmmon.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/bootstrap/monLoader.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/bootstrap/vmmblob.o
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/bootstrap/bootstrap.o
LD [M] /tmp/modconfig-ySDgLm/vmmon-only/vmmon.o
Building modules, stage 2.
MODPOST 1 modules
CC [M] /tmp/modconfig-ySDgLm/vmmon-only/vmmon.mod.o
LD [M] /tmp/modconfig-ySDgLm/vmmon-only/vmmon.ko
make[1]: Leaving directory '/usr/src/linux-headers-5.4.0-14-generic'
/usr/bin/make -C $PWD SRCROOT=$PWD/. \
MODULEBUILDDIR= postbuild
make[1]: Entering directory '/tmp/modconfig-ySDgLm/vmmon-only'
make[1]: 'postbuild' is up to date.
make[1]: Leaving directory '/tmp/modconfig-ySDgLm/vmmon-only'
cp -f vmmon.ko ./../vmmon.o
make: Leaving directory '/tmp/modconfig-ySDgLm/vmmon-only'
make: Entering directory '/tmp/modconfig-ySDgLm/vmnet-only'
CC [M] /tmp/modconfig-ySDgLm/vmnet-only/driver.o
CC [M] /tmp/modconfig-ySDgLm/vmnet-only/hub.o
CC [M] /tmp/modconfig-ySDgLm/vmnet-only/userif.o
CC [M] /tmp/modconfig-ySDgLm/vmnet-only/netif.o
CC [M] /tmp/modconfig-ySDgLm/vmnet-only/bridge.o
CC [M] /tmp/modconfig-ySDgLm/vmnet-only/procfs.o
CC [M] /tmp/modconfig-ySDgLm/vmnet-only/smac_compat.o
CC [M] /tmp/modconfig-ySDgLm/vmnet-only/smac.o
CC [M] /tmp/modconfig-ySDgLm/vmnet-only/vnetEvent.o
CC [M] /tmp/modconfig-ySDgLm/vmnet-only/vnetUserListener.o
LD [M] /tmp/modconfig-ySDgLm/vmnet-only/vmnet.o
MODPOST 1 modules
CC [M] /tmp/modconfig-ySDgLm/vmnet-only/vmnet.mod.o
LD [M] /tmp/modconfig-ySDgLm/vmnet-only/vmnet.ko
make[1]: Entering directory '/tmp/modconfig-ySDgLm/vmnet-only'
make[1]: Leaving directory '/tmp/modconfig-ySDgLm/vmnet-only'
cp -f vmnet.ko ./../vmnet.o
make: Leaving directory '/tmp/modconfig-ySDgLm/vmnet-only'
Starting VMware services:
Virtual ethernet done
Shared Memory Available done
At this point you should be able to run VMware Workstation/Player.
See more at:
