This time installed without selecting the option to update packages, but at end of install still ended up with the 1027 kernel version after reboot with wired ethernet non functional. Took a different approach this time by enabling WiFi and upgrading to 18.10, on reboot wired ethernet is working
I can confirm that the wired network started to work after upgrading up to cosmic cuttlefish. I would like to ask howto remove all of the gui apps to make distro work as a server only with terminal and ssh ? Evertime I used tasksel do purge the unnecesary packages it removed also the whole network subsystem. I canāt install it again without any network connection.
In my case - 3B+
Dear stillwinter
Thanks for info. I need to modify such options to be able to boot. I have done it before without so the image wonāt boot at my Raspberry.
Can I use your preparied img to mixed with the generic server arm64 image ?
The 3B+ was released too late for full support in the 18.04 generic kernel (e.g. ethernet probably doesnāt work), but 18.10 should work okay. If you need to use the Linux-raspi2 kernel with the Debian/text-installers then I gave instructions here AArch64 on Raspberry Pi 2 (rev 1.2), 3B, 3B+ .
At the start of the thread AArch64 on Raspberry Pi 2 (rev 1.2), 3B, 3B+ I also gave instructions to remove the xubuntu packages, but I havenāt fully tested what gets removed.
I have a few questions regarding the setup for arm64.
Iām assuming the correct command is cp /tmp/pi-kernel/lib/firmware/$RASPI_VER/device-tree/broadcom/bcm2710*.dtb . and not cp /tmp/pi-kernel/lib/firmware/$RASPI_VER/device-tree/broadcom/bcm2710*.dtb broadcom, right?
Also how where would I need to copy the overlays? And what are they needed for?
If you connect any addon boards, or if you want to try the vc4 driver. The overlays folder needs to be on the firmware partition because it is used by the raspberry pi bootloader when you have a corresponding device tree overlay line in your config.txt.
Wanting to be able to use my DS3231 RTC. I have added ādtoverlay=i2c-rtc,ds3231ā to config.txt. i2c is also enabled. however, I cannot find the overlay.
Having successfully installed using the 18.04 install USB image and upgrading to 18.10, am scripting the
described process to build a 18.10 USB install image. Has anyone already done this, as might save me a bit of time? Thanks.
I have this running on my Pi B+ but I cannot get the 7" touchscreen to work. I canāt find much info on getting the driver working, I am on ARM64 18.04.
Hello! Thank you so much for this. Was wondering if there is any way to get Ubantu Classic Server 16.04 on Raspberry Pi 3 B+? I am fairly new to this so please do forgive me.
Also I would like to install dotnet-sdk-2.1 (if not later versions).
Is this possible? I am working on a simple project and I cant move forward without installing dotnet.
sudo apt-get install dotnet-sdk-2.2
Reading package lists⦠Done
Building dependency tree
Reading state information⦠Done
E: Unable to locate package dotnet-sdk-2.2
E: Couldnāt find any package by glob ādotnet-sdk-2.2ā
E: Couldnāt find any package by regex ādotnet-sdk-2.2ā
You should be able to install armhf using the mini iso instructions above. You may also find a daily build that can be adapted. For arm64 you can use the generic hwe kernel, follow the instructions on the wiki. This would really only be suitable for a server, not a desktop setup.
This is something you need to google. I've never heard of it before, but from a few seconds of searching it appears to be a Microsoft product and arm packages are not readily available. There seems to be a solution with docker?
Hope somebody can lend a quick hand.
Installed this on Raspberry Pi B+. All good. Except bluetooth which doesnt work.
Icon is there, I turn it on, but whenever I try to add a device the blueman assistant prompts me "No adapters found". Any ideas how to fix this?
I had Ubuntu Mate 16.04, the raspberry flavor, previously. There were other issues with it but bluetooth worked fine.
