Availability of Mate 18.04LTS in Australia
Could someone tell me please when Mate18.04LTS will be available as an upgrade in Australia? I’ve downloaded the .iso but would prefer to use the inbuilt Software Updater. Thank you.
I have asked this question and it's Not only in Australia, but world wide.
You will see it in the software updater in July or August.
below is my post and the answers' from members explaining why.
(personally i will wait August/appear-in-the-software-updater for a safer upgrade)
You can’t upgrade directly from 16.04 to 18.04 at this moment.
you can do it but in steps through intermediary release like 17.04 /17.10
Go in “software updates” and enable from “Updates” tab on “Notify me …” select “For any new version…” then close and go in terminal and apply “update” and “upgrade” and after “do-release-upgrade”, and repeat the step until you are in 18.04.
Search for internet the process in more detail, if you do not understand what I say above.
Thank you for your responses. I’m fully conversant with the upgrade process and my question has been answered - 18.04.1 (first version update) in July. Thanks PaulW2U.
Cheers.
Hi all,
this might interest someone?:
