When I try to use the shortcuts (Alt + LMB, Shift + Alt + LMB) to use this command inside blender, it happens nothing while using the "Shift + Alt + LMB" one, and the "Alt + LMB" causes to change the program tab size. It appears that I can't use this shortcuts in MATE
Some keyboard shortcuts in Blender (and/or other software) can overlap with standard shortcuts. You might want to reconfigure Blender's or UM shortcuts to avoid such a clutter.
opened the shortcut menu and deleted the overlaping commands, but the issue persists.
Have a look at a probable solution here:
