I had the blue filter software "redshift" installed and then upgraded to 24.04.1. After the upgrade redshift behaves not as intended. I uninstalled "redshift" and "redshift-gtk" and installed everything but the problem persist.
A search for redshift on this forum will get you some nice results
Like this:
or this:
or this
and probably some more
Sorry that I can't be more specific due to lack of info on your case.
Anyway, regardless of the nature of your bug, redshift is dependent on geoclue2 which is permanently out of service so pick a solution or replacement as mentioned in one of the above threads .
