So I noticed that my integreated bluetooth adapter does not work . If I do " rfkill list " it does display only the wireless adapter . When I try to start blueman from Control Center it gives me that " Bluez is not running " . Please help !?
System : Ubuntu Mate 15.04
Hardware : HP Compaq 6510b
lsusb output
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 007 Device 002: ID 0e8f:00a5 GreenAsia Inc.
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 08ff:2580 AuthenTec, Inc. AES2501 Fingerprint Sensor
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Hi IvCHo,
Maybe it has nothing to do with your problem, but in [another topic][1] I explained the solution I found (from another website) for my bluetooth headphones issue:
What is interesting is that for this to work, some bluetooth packages need to be purged on line 1 before being reinstalled on line 2.
I cannot say whether it would help in your case but maybe something to consider.
[1]: How I got my bluetooth headphones to work
When I do the purge of bluez it gives me that it will delete ubuntu-mate-core and ubuntu-mate-desktop and if i do that my Mate Desktop will be deleted . When I do sudo apt-get install bluez-* it again gives me that ubuntu-mate-desktop and ubuntu-mate-core will be deleted .
pactl load-module module-bluetooth-discove gives the output 22 so this means it is started .
I understood that this behaviour is normal because these are meta packages (which happens when you want to remove an application like e.g. pluma or pidgin in your example) and that removing them will not break your distro. @Wimpy, can you please confirm?
In Ubuntu MATE 14.04 and 14.10 the unofficial build system uses meta-packages, which means if you try and remove a package within ubuntu-mate-desktop it will also remove the parent meta-package.
This limitation is removed in the official images from Ubuntu MATE 15.04 and onward.
The Bluetooth “fix” outlined above I’ve seen on various blogs, the package removal step is completely pointless.
