Hello!
I’m from Romania and do not speak English.
I write this letter in Romanian and translate it using Google Translate.
In 2013, I bought this laptop HP650 Notebook PC that had installed the operating system, Ubuntu 12.04LTS. The laptop has built-in Bluetooth and that system worked, and led the F12 key was white, like the other LEDs. After a few months, I upgraded to Ubuntu 12.10. Since then, embedded bluetooth stops working. If you open the Bluetooth Manager, I get a window that tells me:
http://imgur.com/OAxf9f9
If inserted in the laptop, a USB Bluetooth, it works.
I viewed ubuntu.ro forum, but we solved the problem.
Mention that are new to IT and Ubuntu.
If I can help, I am grateful.
All the best!
Thanks for understanding!
Hi Viorel,
have you considered upgrading to either 14.04 or 15.10 which might help solve your problem?:
Ubuntu Mate 15.10:
https://ubuntu-mate.org/wily/
For 14.04 LTS version:
https://ubuntu-mate.org/trusty/
Hello!
I had other problems and got the suggestion to install Ubuntu 14.04 per clean. I upgraded to 15.10 and installed on a USB stick, along with Ubuntu 14.04, Ubuntu 15.10 MATE downloaded from its website when the final version appeared in October 2015. We did this with the hope that it will Bluetooth resolve the problem with the laptop. I admit I use daily and I just installed Ubuntu 15.10 MATE all updates received.
Missing from the package open Bluetooth system?
When I click the Bluetooth Manager, I window appears:
Did you try this?. ![]()
I’m not sure what’s wrong so please take your time and browse through these pages, you might find an answer!:
https://help.ubuntu.com/community/BluetoothSetup
https://help.ubuntu.com/stable/ubuntu-help/bluetooth-connect-device.html
Try in terminal
sudo rfkill unblock all && sudo service bluetooth start
After placing two orders and password appears user @ user-HP-650 Notebook PC.
Sorry but I am not quite sure what you mean, can you elaborate please? (Explain in more detail!).
All the above is telling us is that you run the commands (without errors by the look of it)!.
What device are you trying to run?.
sudo rfkill unblock all && sudo service bluetooth start.
You didn't answer this question!. ![]()
I want to unlock Bluetooth, as described above.
lulu@lulu-HP-650-Notebook-PC:~$ lspci
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:02.0 VGA compatible controller: Intel Corporation 2nd Generation Core Processor Family Integrated Graphics Controller (rev 09)
00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.2 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 3 (rev c4)
00:1c.3 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 4 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation 7 Series Chipset Family LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04)
01:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 07)
02:00.0 Network controller: Ralink corp. RT3290 Wireless 802.11n 1T/1R PCIe
02:00.1 Bluetooth: Ralink corp. RT3290 Bluetooth
03:00.0 Unassigned class [ff00]: Realtek Semiconductor Co., Ltd. RTS5229 PCI Express Card Reader (rev 01)
lulu@lulu-HP-650-Notebook-PC:~$ rfkill
Usage: rfkill [options] command
Options:
–version show version (0.5-1ubuntu2 (Ubuntu))
Commands:
help
event
list [IDENTIFIER]
block IDENTIFIER
unblock IDENTIFIER
where IDENTIFIER is the index no. of an rfkill switch or one of:
all wifi wlan bluetooth uwb ultrawideband wimax wwan gps fm nfc
lulu@lulu-HP-650-Notebook-PC:~$ rfkill list
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
lulu@lulu-HP-650-Notebook-PC:~$ lsusb
Bus 002 Device 004: ID 04f2:b34f Chicony Electronics Co., Ltd
Bus 002 Device 003: ID 045e:0797 Microsoft Corp. Optical Mouse 200
Bus 002 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 002: ID 8087:0024 Intel Corp. Integrated Rate Matching Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
