https://solus-project.com/2016/12/11/this-week-in-solus-install-40/
I’m glad to hear that Ikey from Solus might bring the new menu that is desperately needed in MATE. Here he talks about it if anyone wants to listen:
A post was split to a new topic: Areas of Improvement - A Quick Recap
That’s the Whisker menu barely disguised.
Solus MATE has this already, Arch has it, how do we go about to getting Brisk menu on Ubuntu MATE right now?
And yes, I know it is not finished.
I just got it to work and so far so good. I’m running 16.10. It’s under heavy development, so it’s at your own risk! Here’s what I did:
tar.xz file at the top. I’m assuming the filename is brisk-menu-0.2.0.tar.xz. Cange it if you are installing a different version.~/Downloads.tar -xvf brisk-menu-0.2.0.tar.xz
cd brisk-menu-0.2.0
./configure --prefix=/usr make sudo make install
sudo make uninstall in the same directory.Thanks for the instructions, I gonna try on 16.04
Can’t hurt to try, but I think it requires GTK+ 3, while MATE in 16.04 is GTK+ 2. I guess it will come down to how much it depends on GTK+ 3 MATE-specific libraries that are not in 16.04 versus general GTK+ 3 Ubuntu/GNOME libraries that might be in 16.04.
I think your right… I got this on ./configure --prefix=/usr
`configure: error:
Package requirements (
libmate-menu >= 1.16.0
) were not met:
Requested ‘libmate-menu >= 1.16.0’ but version of libmate-menu is 1.14.0`
Here are all the required libraries that need to be installed :
A complete command would therefor be sudo apt install libgtk-3-dev libmate-menu-dev libmate-panel-applet-dev libghc-gio-dev
Hope this helps
A fresh install doesn’t include the compiler and autotools (IIRC), so if you’ve never compiled something youprobably also need to
sudo apt install autoconf automake build-essential
Thanks a lot!
This is what I needed on fresh install of 16.10:
sudo apt install build-essential libglib2.0-dev libgtk-3-dev libmate-menu-dev libmate-panel-applet-dev
The only issue I have with this build of Brisk Menu is that it doesn't have "Preferences" category and as result searching from menu for items in that category, "Mate Tweak" for example, doesn't come up with a result. Small potatoes ![]()
Still IMHO the most useful menu of the available options.
Now all is left to figure out how to customize clock font (size) and I will finally have a Desktop Environment that checks all the boxes I need. Makes me happy ![]()
Can the Mate Tweak app be opened in another way? (can’t test it atm
Yes, in Control Center.
wow thats great, this is the kind of innovation Mate needs to stay future proof. I highly appreciate this kind of work! Keep going
Martin announced a PPA for Brisk Menu, for 16.10 and 17.04.
It’s nice and fast, but I like how the Mate menu changes the applications list on hover over the categories, Brisk menu requires mouse clicks.
That’s the kind of feedback you should make upstream ^^
Maybe a feature request on github?
Cheers
Done.
[Length requirement]
