Whenever I try a theme in MATE I start by checking whether Caja displays correctly. As it turns out, there a very few light themes which play well with Caja. When you have Caja divided into two panes and click a file or folder to mark it, then click an item in the other pane, the previous item is invisible - the theme displays text in white on white background:
Only a few light themes do not cause such a behavior (e.g. Ambiant-MATE). It does not happen with dark themes, as they display text on a dark background.
Now, where do I look in the theme files to change the text color of a marked but unfocused item in Caja?
Any suggestions will be much appreciated.
