Hi
I’ve installed 17.04 Ubuntu MATE and I really like the polish, customisation and integration this DE has.
However, I’ve noticed that when I insert media (DVD disc, USB drive etc) all I get is the icon on the desktop. I have to manually open the media with the relevant software. Caja controls these things yet nothing else happens. I have checked Caja’s settings as in this post:
but not even autoprompt runs. I can’t find an option in dconf to enable/disable and there doesn’t appear to be any related plugin or package in repositories. My question - is this the default behaviour or is there a way to activate Autoplay/Autorun?
Thanks
Rich
EDIT:
I should have said the version I was using was 17.04 and is the first time I’ve tried Ubuntu MATE. I’ve since installed 16.04 and the problem is not there in the LTS version.
