Hello Mate Community,
While in a Caja’s maximized window, it can’t scroll down to the lowest bottom area of caja’s window where the last row of icons reside (Ctrl + 1). A workaround is to unmaximize the window, so it can fully scroll down thus revealing the last row of file icons.
Is this a known bug? Is there a solved status?
My best compliments
