As you can see below, there are some difference between the clean install 22.04 Control Center , Administration section and my own 20.04 one. 3 possibilities are missing.
I've installed 'Synaptic Package Mgr' myself, and I will probably do that again, and I'm working to add 'Users and Groups' via another question ( Unable to add a new user ) But 'Login Windows' is also missing.
Because I sometimes use my daily driver to demonstrate Linux, Ubuntu and Mate in particular, I'd like to impress people with a magnificent logon-screen. I can't do it from a standard 22.04 install.
will it be solved when my probleem with the gnome-system-tools is solved ?
I am amazed that a component is kept despite the fact that it reduces functionality. Because the "Login Windows"'s functionality goes beyond simple background changing. IMO, this is a step back.
Nice, and does it work on 22.04 too?
I'm a bit scared about the very long command. I'm not afraid of the CLI, but this is ... big.
It only solves the problem of the bg, not other functionality.
