Is there any way to send codes to colourize text in the MATE terminal?
For example, I might want to highlight only the word 'good' in the following sentence, by sending a code before and after 'good'..
"That was good work."
I know it can be done on a number of terminals (VT100, is one).
Yes, there are several ways:
You can use ANSI escape codes directly
( ANSI Escape Codes · GitHub ) -
You can also use the terminfo utility from the commandline or from a shellscript by using the command
tput( seeman tput)
Below is an overview of some colorcapabilities of tput:
Foreground color
tput setaf 0 # black
tput setaf 1 # red
tput setaf 2 # Green
tput setaf 3 # yellow
tput setaf 4 # blue
tput setaf 5 # magenta
tput setaf 6 # cyan
tput setaf 7 # white
background color
tput setab 0 # black
tput setab 1 # red
tput setab 2 # Green
tput setab 3 # yellow
tput setab 4 # blue
tput setab 5 # magenta
tput setab 6 # cyan
tput setab 7 # white
character attributes
tput bold # bold
tput dim # half-bright
tput sgr0 # reset to normal
tput smul # begin underline
tput rmul # end underline
tput rev # reverse
tput smso # begin standout mode (bold on rxvt)
tput rmso # end standout mode
So you can do:
echo "That was $(tput bold)good $(tput sgr0) work."
But if you want to use it a lot , it is ofcourse highly inefficient to call tput again and again.
To optimize that I always use it like this:
B=$(tput bold)
N=$(tput sgr0)echo "That was ${B}good${N} work."
in ANSI:
echo -e "That was\033[1m good \033[mwork."
With ANSI escape codes you can use full 8-bit per color on mate-terminal although it is beyond the capabilities of some other terminals.
try this script:
#!/bin/bash
for red in {0..255..5}
do
for green in {0..255..5}
do
for blue in {0..255..5}
do
echo -ne "\033[38;2;${red};${green};${blue}mX\033[0m"
done
done
done
Note, vt100 does NOT support color codes, it was a black and white only terminal, vt102 and vt220 and ansi are all terminal types that DO support ANSI color codes.
Correct, it did only support bold, dim , reverse, blink, keyleds and cursorcontrols.
I'm not sure if it did underline, can't remember, too long ago since I used a vt100
For a complete list, see:
https://www.csie.ntu.edu.tw/~r92094/c++/VT100.html
