Using Mate 17.10…I like using Compton for no screen-tearing. Problem is, when using Mate Tweak to enable it, it also adds a fade effect, which I find annoying. I would like to disable the fade effect.
I see that I can use my own compton.conf file, and that in that file I can specify no fade effect, but I don’t want to create the whole thing from scratch. I’d basically like to take the configuration that Mate Tweak uses by default, and simply disable the fading effects.
In the running processes, I do see that compton is running, and I can read the command line output. I thought I could simply copy that, but I don’t see a way to copy the command using the system monitor.
Any suggestions?
