Hello,
First of all i sorry if this topic was discussed befeore. I searched but did not found anything to this.
So.. The problem is, that after i installed the Ubuntu Mate 20.0.4, rebooted in the new installation and after the lightdm login the desktop was fragmented and can not be used. I enter a new tty and update and upgrade it via cli, the rebooted and it seems that does have no effect.
If anyone encountered that before please leave a comment.
Thank you
Welcome to the community @George_Guta .
Which graphics card do you have? Does the following issue similar to yours and the provides suggestion helps.
sorry if i posted this in the wrong place as it is my first time on this forum, and my english is not very good as i use translator.
I currently use Ubuntu 20.10 and I decided to install MATE on it, when I switch to the MATE desktop the screen looks very choppy, I thought it was Ubuntu's error and I decided to try Ubuntu MATE and installing it brought me the same surprise, before I tried ubuntu mate 18.04 lts and it worked perfect for me, but with the most recent version no longer, and I don't…
http://ubuntuhandbook.org/index.php/2018/07/fix-screen-tearing-ubuntu-18-04-optimus-laptops/
Hello,
Thank you for ypur answer. It's my fault i forgot to say that i use a Lenovo laptop IdeeaPad with AMD Ryzen 5 as CPU and Vega 8 mobile as video card.
My issue is very similar with this one( identical)>
[20.04_live]
I have a Lenovo Ideapad 130-15AST. So as not to bloat the thread I put the output of lshw in pastebin here:
https://pastebin.com/NMBigV4G
The above picture is what the MATE 20.04 live USB boots to.
I first upgraded from 18.04 using do-release-upgrade. The result looked like the photo as well.
Then I reinstalled 18.04, upgraded to 19.10, which looked and performed normally. I then upgraded the 19.10 install to 20.04 with the same result as the photo.
I also tried with a diffe…
I tried the fix sugested here:
https://www.reddit.com/r/xubuntu/comments/gb9jiu/xubuntu_2004_amdusers_garbled_display_fix/
But the problem still persist.
Any help will be much appreciated
Thank you
