Hello, Sometimes there are duplicates in the mate-panel (see picture with the duplicate bluetooth icon).
The problem is very recurring but can be easily fixed, either by restarting the computer or with the 'mate-panel --reset' command. Is there a solution to this problem? Am I the only one with this problem?
Hi
I have similar problem but with wifi icon this help me.
https://ubuntu-mate.community/t/two-network-icon-in-notification-bar-ubuntu-mate-20-04/21636
Maybe if you do the same and delay blueman applet at startup the duplicate Bluetooth icon will disappear.
Oh thanks, I'll try. Sometimes for me too, it's the wifi icon that is duplicated.
Edit : It seems to work !
