The design is intended to use Numix icons. Oomox is completely useless for this as I tried to see if I couldn't use the current iteration of Numix icons (I tried), and since Numix is incredibly flat I don't think it would be an issue for the art team to fart out a hue-shifted Numix variant in GIMP or use something else they agree upon.
The FM theme in the cap isn't something I find particularly appealing, and is probably exclusive to the author. Then again I was just doing some research for myself and encountered it. and from further reading seems like something that only works in Nautilus? I am not sure. I also don't feel like testing it, and since it's from a PPA my copy is probably outdated.
If the Material / Flat look isn't what the art team wants to do, then this concept is stillborn. Apologies if the capture doesn't explain fully what the hell the theme is, if you want to fetch it you can get it here; https://www.mate-look.org/p/1220749/
My installation is from NoobsLab's theme repository for Cosmic / Bionic.
Might somebody be able to point me in the right direction? I am looking for a blue accented version. In other words, everywhere where are you see green I would like to see blue. I like everything else about this desktop environment, I just would like to see something different than this gawdy green. No offense to those who like this particular color.
Specifically, I want everything to look exactly like it is, except the color. Is there an Ambient Mate blue theme that anyone is aware of that looks identical to this default theme?
Oh hey, I figured out ow to get numix-folders working so people no longer need to roam about looking for a competent, colour-matching icon set when they can just roll their own.
I just wish more themes exercised something similar for their own icon suites so users aren't locked to a certain colour.
If you love Arc Dark, you'll love Linux Mint's Mint-Y series of themes. Wrote a guide about it here.
Might remodel that guide since the URLs had changed since, just grab packages for latest Linux Mint and install it. No time for redos as of present. What you get in return are a bunch of Greybird and Arc derivatives with varying colours so you can have a rotating selection of Arc-alikes with corresponding icon suites. Did it.
For quite some time now, I use Numix theme and Obsedian icon set. While testing 19.10 Beta, Caja showed blue, but I don't know what theme this was as I upgraded from 19.04 to 19.10 Beta in Virtualbox.
sudo apt install numix-gtk-theme
Because Numix has got a dark window border, I use the Ambiant Mate to see where I have to close the windows.
I downloaded the Obsidian icon set from ??? It has got 10 or more colors. I like the Light-brown one.
Personally I like the green color however on a more pragmatic approach it could be a very nice choice if future releases would have some sort of "wizard" for first logins, such as creating username, selecting the application favourites, color theme and possibly other things such as a picture, etc.
You might be interested in numix-folders but you have to follow my gksu installation guide first because that software uses outdated methods of elevation to make it work.
Funny thing: gksu isn't necessary at all if you're modifying a copy of the Numix icons in ~/.icons using that tool but you still cannot run it without gksu because there's no failover (i.e. telling the user it'll only work for a local copy of the icons) in the case a user isn't in /etc/sudoers.
Words cannot express the stupidity this is, and the anger I feel about that. (Because they'd be censored!)
Thanks for the tip. I'm not interested in Numix icons, as I'm happy with my Obsidian icons. But I will give the ubuntu-mate-colours project a try in Virtualbox.
It's ok, actually pretty nice, but for me personally its to dark, though most dark themes have that problem, for me ambiant mate dark is the right shade of dark for a dark theme, the same reason I'm not a fan of the new yaru dark theme even though I generally prefer dark themes, but overall good work.
p.s. also on my setup the firefox back button is to light to see the icon very well, idk maybe it is a Materia issue though
edit: also your titlebar theme works really well with the menta theme which I am currently using, with the exception of csd app, I'm actually going to keep using it this way for a bit as I like the bigger buttons compared to menta
Software like the firewall or the lightdm settings remain white with the dark variant of the theme. Happens as well for other Materia variants like Vimix. Don't know how to fix it.
Other than that, looks cool.
Is it installed in /usr/share/themes? If you install it in ~/.themes, that's probably the reason - the root user (which is needed for the firewall and lightdm settings) dosen't know where it's located. Try copying the theme dir to /usr/share/themes.
It works indeed as intended once installed in /usr/share/themes.
I used to tweak Materia with change_color.sh and would always face this problem.
Thanks a lot !
