I have two machines running UM 24.04. The first machine (newer) can detect and mount the External USB SSD drive with no issues. The second (older) cannot. This is what I get with dmesg:
[21380.945673] usb 1-1: stat urb: status -71
[21380.945726] scsi 6:0:0:0: tag#28 uas_zap_pending 0 uas-tag 1 inflight: CMD
[21380.945737] scsi 6:0:0:0: tag#28 CDB: Inquiry 12 00 00 00 24 00
[21381.955294] usb 1-1: new high-speed USB device number 6 using xhci_hcd
[21382.082578] usb 1-1: New USB device found, idVendor=0634, idProduct=5600, bcdDevice= 1.00
[21382.082594] usb 1-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[21382.082602] usb 1-1: Product: Crucial X8 SSD
[21382.082609] usb 1-1: Manufacturer: Micron Technology Inc
[21382.082615] usb 1-1: SerialNumber: 1943E3282790
[21382.090324] scsi host6: uas
[21382.345933] usb 1-1: USB disconnect, device number 6
[21382.346487] scsi 6:0:0:0: tag#0 uas_zap_pending 0 uas-tag 1 inflight: CMD
[21382.346501] scsi 6:0:0:0: tag#0 CDB: Inquiry 12 00 00 00 24 00
[21383.353309] usb 1-1: new high-speed USB device number 7 using xhci_hcd
[21383.480571] usb 1-1: New USB device found, idVendor=0634, idProduct=5600, bcdDevice= 1.00
[21383.480590] usb 1-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[21383.480598] usb 1-1: Product: Crucial X8 SSD
[21383.480604] usb 1-1: Manufacturer: Micron Technology Inc
[21383.480610] usb 1-1: SerialNumber: 1943E3282790
[21383.486635] scsi host6: uas
[21383.742549] usb 1-1: USB disconnect, device number 7
[21383.742710] usb 1-1: stat urb: status -71
I truncated it because it just repeats. The only difference in the rest is the tag# and the USB device number.
Additionally, plugging the drive on a different port yields the same error. Plugging different USB thumb drives works with no issues.
I don't know what's happening and would really appreciate some help with this.
Thanks for the solution you came up with. However, both my external USB SSD and the PC I use have US3B3 ports, and I have tried connecting the SSD from the front and rear USB3 ports and got the same error. Also, I do not need the USB SSD plugged in at all times.
What I did try though was create an ignore_uas.conf file with the following line:
options usb-storage quirks=idVendor:idProduct:u
After saving and rebooting, I get this:
{ 437.034561] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 437.034891] usb-storage 1-1:1.0: Quirks match for vid 0634 pid 5600: 800000
[ 437.035055] scsi host6: usb-storage 1-1:1.0
[ 438.329376] usb 1-1: USB disconnect, device number 8
[ 439.336603] usb 1-1: new high-speed USB device number 9 using xhci_hcd
[ 439.463843] usb 1-1: New USB device found, idVendor=0634, idProduct=5600, bcdDevice= 1.00
[ 439.463859] usb 1-1: New USB device strings: Mfr=2, Product=3, SerialNumber=1
[ 439.463868] usb 1-1: Product: Crucial X8 SSD
[ 439.463874] usb 1-1: Manufacturer: Micron Technology Inc
[ 439.463880] usb 1-1: SerialNumber: 1943E3282790
[ 439.466226] usb 1-1: UAS is ignored for this device, using usb-storage instead
[ 439.466238] usb-storage 1-1:1.0: USB Mass Storage device detected
[ 439.466599] usb-storage 1-1:1.0: Quirks match for vid 0634 pid 5600: 800000
[ 439.466730] scsi host6: usb-storage 1-1:1.0: USB Mass Storage device detected
No error but the USB SSD still doesn't come up and I cannot mount it as a result.
EDIT: Addendum: Inserting USB thumb drives (USB3/USB2) on the same ports work.
Have you tried booting a different distro on the machine that fails? You can use a live cd image to test including a U-Mate 24.04 image in case the installation went sideways.
If it fails on other distros I would conclude that it's a hardware problem. If so, you can live with the situation or report it as a bug specifying the hardware used (both the computer as well as the external ssd).
Oh... , Indeed, you're right.
How I came to think of USB2 is a mistery.
Anyway, There still is a possibility that the power for the USB ports is not up to par, so trying it with an external powered USB-hub might give some certainty about that.
