Trying to analyze this other reported issue prompted me to experiment and create this little ad-hoc tool, just for the hell of it! It makes use of the usb-devices command.
What better way to spend your retirement! ![]()
Entering the command
Devices__ReportUsbDetails.sh --idVendor 046d --idProduct c077
will report as
COMPONENT: Logitech, USB Optical Mouse
T: Bus=03 Lev=01 Prnt=01 Port=01 Cnt=01 Dev#= 2 Spd=1.5 MxCh= 0
D: Ver= 2.00 Cls=00(>ifc ) Sub=00 Prot=00 MxPS= 8 #Cfgs= 1
P: Vendor=046d ProdID=c077 Rev=72.00
S: Manufacturer=Logitech
S: Product=USB Optical Mouse
C: #Ifs= 1 Cfg#= 1 Atr=a0 MxPwr=100mA
I: If#= 0 Alt= 0 #EPs= 1 Cls=03(HID ) Sub=01 Prot=02 Driver=usbhid
E: Ad=81(I) Atr=03(Int.) MxPS= 4 Ivl=10ms
As you can see, it gives the full detail reported by the "usb-devices" tool, but it adds the corresponding "COMPONENT" description as the first line for every device reported, for quick recognition.
Devices__ReportUsbDetails.sh :
#!/bin/bash
### Script to translate "cryptic" USB device reporting into human-relatable description
### Typical log entry when trying to debug
#[ 439.463843] usb 1-1: New USB device found, idVendor=0634, idProduct=5600, bcdDevice= 1.00
idVendor="-1"
idProduct="-1"
while [ $# -gt 0 ]
do
case "${1}" in
"--all" ) usb-devices ; exit ;;
"--idVendor" ) idVendor="${2}" ; shift ; shift ;;
"--idProduct" ) idProduct="${2}" ; shift ; shift ;;
"--debug" ) dbg=1 ; shift ;;
"--test1" )
### Hardcoded local test case #1 - Single component (USB Mouse)
idVendor="046d" ;
idProduct="c077" ;
shift ;
"--test2" )
### Hardcoded local test case #2 - Multiple component (USB ports)
idVendor="1d6b" ;
idProduct="0001" ;
shift ;
esac
done
if [ "${idVendor}" = "-1" ] || [ "${idProduct}" = "-1" ]
then
printf "\n\t Script requires reported values for both --idVendor {} and --idProduct {} \n\n" ; exit 1
fi
usb-devices |
awk -v dbg=${dbg} -v idvendor="${idVendor}" -v idproduct="${idProduct}" 'BEGIN{
captureON=0 ;
split( "", details) ;
split( "", size) ;
split( "", descr) ;
indx=0 ;
lastgood=0 ;
keep=0 ;
if( NF == 0 ){
if( keep == 1 ){
size[indx]=attrib ; ### save number of attribute lines
if( dbg == 1 ){
printf("\n\t attrib = %d\n", attrib ) | "cat 1>&2" ;
lastgood=indx ;
}else{
indx=lastgood ; ### reset index to discard any details captured for last item
keep=0 ;
captureON=0 ;
if( index( $0, "T:" ) == 1 ){ ### First line of every BUS item
captureON=1 ;
indx++ ;
if( dbg == 1 ){
printf("\n\t indx = %d\n", indx ) | "cat 1>&2" ;
attrib=0 ;
size[indx]=0 ;
if( captureON == 1 ){
attrib++ ;
if( dbg == 1 ){
printf("\t\t attrib = %d\n", attrib ) | "cat 1>&2" ;
details[indx,attrib]=$0 ; ### capture raw line for reporting
#P: Vendor=046d ProdID=c077 Rev=72.00
if( index( $0, "P:" ) == 1 ){
split( $2, vend, "=" ) ;
vendor=vend[2] ;
split( $3, prod, "=" ) ;
product=prod[2] ;
if( dbg == 1 ){
printf("\t\t vendor = %s idvendor = %s \n", vendor, idvendor ) | "cat 1>&2" ;
printf("\t\t product = %s idproduct = %s \n", product, idproduct ) | "cat 1>&2" ;
if( vendor == idvendor && product == idproduct ){
keep=1 ;
#S: Manufacturer=Logitech
if( $2 ~ /Manufacturer/ ){
split( $0, mfg, "=" ) ;
manufacturer=mfg[2] ;
descr[indx]=sprintf("COMPONENT: %s", manufacturer ) ;
#S: Product=USB Optical Mouse
if( $2 ~ /Product/ ){
split( $0, prod, "=" ) ;
product=prod[2] ;
descr[indx]=sprintf("%s, %s", descr[indx], product ) ;
}END{
if( keep == 0 ){
indx-- ;
for( i=1 ; i <= indx ; i++ ){
if( size[i] > 0 ){
if( indx > 1 ){
printf("\n==========================================================================\n" ) ;
print descr[i] ;
for( j=1 ; j <= size[i] ; j++ ){
print details[i,j] ;
exit
