Why does file system capacity in Disk Usage Analyzer shows higher capacity (exactly 1 TB) if the real disk capacity is 512 GB?
Do you have two 512 GB disks attached? Or maybe a 512 GB medium and several other media that together add up to about 512 GB?
The Disk Usage Analyzer shows the combined capacity of all file systems that are present and mounted; it does not just show the capacity of the primary or root file system.
