Hey, is it possible to install GIMP? How? I haven't found a way to install flank.
GIMP is in the repositories. You can use apt (CLI), Synaptic (GUI), Software Boutique, or your choice of methods.
I have no idea what "flank" is, and can't find anything on a search.
https://www.flatpak.org/
My be that yow meaning?
Thanks, unfortunatelly there is an error stayiting that some dependencies could not be install. How to debug?
Well, it gives me this error message:
gimp : Depends: libgimp2.0 (>= 2.10.18) but it is not going to be installed
Depends: libgimp2.0 (<= 2.10.18-z) but it is not going to be installed
Depends: libgegl-0.4-0 (>= 0.4.22) but it is not going to be installed
are you on UM 20.04 ?
make sure your system is up-to-date
sudo apt update; sudo apt upgrade
to fix broken pkgs, sudo apt install -f
Yes, I am on 20.04.
And your post is still not 20 characters long, have you tried the heart button?
--Why my post should be more than 20 chars long?
--Where is the button of love?
Still the same problem.
Let's make sure your system is up-to-date.
After sudo apt update it should report, All packages are up to date.
Yes, the system reports it's up to date.
Maybe thru ppa otto-kesselgulasch?
sudo add-apt-repository ppa:otto-kesselgulasch/gimp
sudo apt install gimp
Here is the official Debian repository. Hopefully one will meet all the dependencies.
https://packages.debian.org/search?searchon=names&keywords=gimp
Why replying to me ? I know how to install gimp and i use manjaro-mate!
Sorry, hit the wrong reply button, should have been reply to Juandev
It's ok ! About install gimp i think is little tricky with dependencies and must be advance user to deal with it. My opinion !
So could you explain to me that error message?
- Depends - so I guess it means GIMP depends on this
- libgimp2.0 - it is the name of the file on which it depends. By the way is it a GIMP file, Ubuntu file, or what?
- <= 2.10.18-z - what is this? Is it a version and operator saying I need a lower version of that?
- but it is not going to be installed - so if it is not going to be installed I think it's not in the GIMP package I have downloaded. It takes me to my question in 2.
Same problem. If I try to install dependencies I get into something like libopenexr23 which is not in the repo.
@Juandev, would you like to try snap version of GIMP? This comes with all required dependencies built-in.
For snap package, the command is,
snap install gimp
The other format is flatpak which @joe has already pointed out. Have you tried it and didn't work? Hopefully, one of the two formats (snap or flatpak) should work fine for you.
Yup, this worked. Thank you. Yes I have had installed flatpak, but I had no idea how to use it. Now I see it would by something like "flatpak install gimp" or so.
i think this will help you.
