Gooday..
I just installed ubuntu MATE 64bit to my old nettbook but I have encountered a problem with wallpaper,,every time I configure it it seem to be croped..
Here my nettbook spec
intel GMA3150 graphic hardwere
intel atom N445 1.66Ghz
vga display 1024x600(no lcd lid for netbook)
Hi @neko_zx ,
right click the desktop > Change Desktop Background and click on "Style " for other display options!.
thanks for the help mate, I find span setting work best for me, with a picture sized 1500x1061 px...
I'm realy sorry about the pictures...I try my best to find other image but I can't found other image sized that big..
oh btw where can I find theme that you are using and where do I learn about linux...
if anyone interested I got the wallpaper..
here
Hi @neko_zx ,
install Synaptic (if not already installed) and then type "wallpaper " in search and select all the wallpaper packages you want!.
To install it via a terminal (Ctrl + Alt + t):
sudo apt-get install synaptic
The theme is "TraditionalOKtest": Control Centre > Look & Feel > Appearance > Theme :
See also:
WARNING 1:
BACKUP ALL YOUR DATA BEFORE YOU START TO INSTALL IN CASE THINGS GO WRONG!. SAVE ALL YOUR IMPORTANT FILES AND FOLDERS TO EITHER AN EXTERNAL USB DRIVE AND/OR TO A 2ND HARD DRIVE ON YOUR PC. DO NOT SAVE ANYTHING ON THE SAME DRIVE YOU INTEND TO USE FOR LINUX UNLESS YOU UNDERSTAND/KNOW WHAT YOU ARE DOING!. ONCE YOU START PARTITIONING AND YOU COMMIT TO FORMATTING YOUR PARTITIONS, THERE IS NO GOING BACK!.
WARNING 2:
IF YOU HAVE A RECOVERY PARTITION AND HAVE NOT CREATED ANY RECOVERY DISKS FO…
thanks mate…
goodday:yum:
Hi @neko_zx ,
if this is now solved, please tick best answer so it helps others!.
