So since I installed my Ubuntu mate I'm i get two WiFi signals indicator which is kinda annoying .Any help ?
https://www.dropbox.com/s/n3n0rk6nca4z8nj/Screenshot%20at%202019-06-03%2006-14-28.png?dl=0
Which version of Ubuntu-MATE?
Does it repeat when you reboot?
Have you run all the updates?
Thanks
Are you using more than one WiFi adapter, like onboard & USB?
This is being looked at.
Would it be possible for you to following the steps here and file a bug report.
So i decided to switch from mate wm to i3wm that solved some major issues so thanks anyways
