So, I got Ubuntu MATE 16.04 installed and running on my PowerBook G4 with a Radeon 9700 GPU. However, it appears I have no 3D acceleration. When I input glxgears into the terminal, I get this return:
libGL error: No matching fbConfigs or visuals found
libGL error: failed to load driver: r300
libGL error: failed to load driver: swrast
Error: couldn’t get an RGB, Double-buffered visual
I have the following set as a yaboot startup parameter:
image=/vmlinux
label=Linux
read-only
initrd=/initrd.img
append=“Linux radeon.modeset=1 video=offb:off video=radeonfb:off video=1280x854-32 radeon.agpmode=-1”
While searching for a solution, I was directed to this bug report:
https://bugs.launchpad.net/ubuntu/+source/mesa/+bug/1432949
The gist of it is, I need to edit my xorg.conf file to make the default depth 16. Problem is, there is no xorg.conf file. I have no idea where to go from here. Any help would be greatly appreciated.
