HiDPI settings are not applied upon login with nvidia proprietary drivers
Ubuntu MATE 18.04 LTS x86_64
nvidia-396 drivers
1920x1080 display
On opensource drivers it works fine, but it seems that the proprietary nvidia drivers does something that prevents the HiDPI settings to be applied when a user logins.
Is there any way to fix that? Or at least is there a mate-tweak command line options to set HiDPI settings so I can automate as a workaround?
Also found this bug report with another workaround:
But it's not a very graceful way to fix things...
Bug report on mate-tweak's github:
Thanks
