Thanks Mr. Pavlos.
Is there a spot on the Mother Board where I can tap in and use the 12 volt d.c. current ?
I have a 12 volt external power supply, but I would like to make it look fairly pretty.
Thanks Mr. Pavlos.
the molex connectors (red[5V], black [GND], black [GND], yellow[12V]) provide 12V & 5V. Look at the label of the fan, it may say 5V since I see 3 pin connectors which should be 5V.
If re-installing is an option for you - then, yes, I would do that because your package sources seem broken e.g. the error you reported:
It is possible to fix this without re-installing if you end up needing to.
The power connectors are 3 black wires.
I assume that 2 of the 3 leads as shown are for the d.c. voltage and the other is for fan speed regulation.
I am sure that that Nvidia is not aware that red is generally positive while black is negative. That may be their story and they are sticking to it. ![]()
P.S. Hewlett Packard gets the gold star for making the hardest product for dis-assembly.
I fished a printer out of a dumpster.
I am known as a known as a dumpster diver.
As a retired chemist, I wanted to know how it worked and what could I do to
uses some of it's parts.
At one point, I had to use a hammer to disassemble it.
After about 6 or 7 blows I decided to give up.
