QUESTION:
Is there a 'sudo' or tool I can use that will seek, find and describe what my Wi-Fi card is on Laptop without opening laptop and it's driver? Apparently, AC/ or n,g,b matters.
WHY:
On a 300 Mbps plan, CABLED I'm getting 270 - 345 Mbps with zero bufferbloat.
Wi-Fi, I get 23-30 Mbps huge bufferbloat
I hope to find a good driver, or source the issue and fix it.
INSTALLED:
Ubuntu-Mate 18.04 on a 'was Windows 10' Samsung laptop (totally reformatted Windows out of the picture before install)
Start the hardinfo tool (menu: System Tools/System Profiler and Benchmark).
Select Devices, then PCI Devices and scroll down to your network devices. If your network is not there it may be under USB Devices.
Thanks radax05. Unfortunately, it doesn't show my WiFi but Daves solution (below yours) shows the model and with that, I could search for the card, but in the last few weeks, Google,Binh, Start and Duck have built a electronic Trump-wall around Canada, and very hard to escape and search the WWW instead of just Amazon and ebay. Information now days is what's for sale and how much - next door. The WWW is now Local Wide Web.
I'll be in the U.S. next week and will borrow a U.S. device and search then. I hope someone re-invents the WWW real soon. Before the World Wide War
The issue I have is with my ISP who says on a 300Mbps "Plan", and only getting 25Mbps Up is because I need a 802.11 /AC, not /n, g, or b
I believe that my card is a 802.11 /N and read that /N should be as good as /AC
NOTE: Cabled, I get speeds of 270 - 350 minimal bufferbloat, but wi-fi = 14 - 26 Mbps with high bufferbloat.
I used that command as you suggested, so I could discover what my 802.11 IS, Following most descriptions, your's says it is a "802.11 A/B/G".
My "product" line just gives manufacturer and model number maybe because it's a laptop - well, thanks anyway mdooley. I appreciate you're taking the time. I'll try calling the manufacturer because their a site is was no help.
I'd post back a copy, but I',m unable to connect 99% of the time, and lose signals. Stuck with Windoze - still.
My wifi uses a Broadcom device, not an "802.11a/b/g" device. The manufacturer and model are extremely important, the a/b/g not so much. It would be nice for you to follow requested instructions.
@ mdooleyModerator
I simply posted the results of the terminal command from the instructions you gave me. I responded with a copy of the result.
Leaves me wondering what I did, or didn't do, to irk your ire.
The link you most recently provided, (I just saw) information is 6 years 5 months old and for Ubuntu 12 not 18.4.
I do search elsewhere/anywhere BEFORE stepping in to it.
Thanks Internaut. Sorry to have bothered you. I posted my results so that you might compare them with the results that you posted and see if you could do better.
My previous links were an attempt at illumination. Please see yet another -
My apologies. It was the way it was worded. I took it mean to be a sarcastic suggestions with:
and I hadn't seen any instructions and the link resulted in tonnes more of stuff to read.
My ISP plan is for 300 Mbps but I get 0.5 to maybe 60. They wanted to know what my Wi-fi card is and without opening up the laptop, I asked if there wasn't a way in Ubuntu-M to find it. Again, I misinterpreted your suggestion to be sarcasm. My mistake.
It does not show what the suffix /n/g/b/a/c might be.
It very much matters. FYI: /g /b for example, are not capable of dealing with anything over 100 MBbps - if that. The /AC, according to my ISP, is necessary for the 5G, mesh networks, and speeds over 100Mbps and up to 600 Mbps. It's also how they sell their blocks, instead of 100, or1000 Mbps, they piece it off at higher rates.
The /n MIGHT be capable up to 400 Mbps... according to technet groups.
It's why I'm trying to find out if it is /n/g/b/a/c/ac so I can nail down if it's the card, or the ISP can't get it up and over 70 Mbps. My windoze card is /gb so it will not exceed 100 Mbps not that it would do 100, but 70 maybe. This Ubu laptop is a unknown "802.11" without the amendment designation.
For anyone interested in the lettering sufix, this link explains it nicely. AND, if anyone is wondering or complaining about their speed, search out or google "bufferbloat" as well as make sure your NIC is capable.
From the info you gave mdooley , I was able to find the details for the card, minus the /(amendment) identifier and from that I was able to find the specs online as to what it SHOULD be which isn't always what we end up with. If the data I get from your help, is correct and the find on the 'net is correct then I have a AR9485 Wireless Network Adapter.
Data Link Protocol
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
