how to upgrade from Ubuntu Mate 14.10 to 15.04 ?
should be able to do: sudo update-manager -d
I believe
Y god . Tnx man !
Not a problem mate. Just helping out.
When done you might need to update the Ubuntu MATE specific PPA’s to represent vivid instead of trusty/utopic so that the Ubuntu MATE specific updates can be installed or you could end up with a broken system. Haven’t tried it yet to be honest.
I think I will wait till I get a dvd to install a fresh coppy . Upgrading will take too mutch time . And configs may brick . And I forgot to mount my second partition as /home/ …
