i installed os on usb, system start and work very quick and smooth but after mount any usb device to my laptop, my usb with system is unmount and os freezing all icons gone and menu not working im sorry if ive opened same subject again if anyone has got same problem plese post thank you so much im try hard migrate from windows to linux thank you for your help
Hi @metabarone ,
what version of Ubuntu Mate are you using?:
Have you done a full system update?:
These are my own setting preferences, use at your own risk!.
AN IMPORTANT NOTE FOR LINUX BEGINNERS. WHEN YOU ARE IN RECOVERY MODE, THE KEYBOARD DEFAULTS TO US ENGLISH, IF YOU HAVE ANY OTHER LANGUAGE KEYBOARD OTHER THAN US ENGLISH, WHEN YOU TYPE "Y" (FOR "YES"), IT MIGHT SHOW UP AS A DIFFERENT LETTER, ON MY KEYBOARD I MUST PRESS THE "Z" KEY WHICH EQUATES TO "Y" AS I HAVE A GERMAN KEYBOARD, JUST PRESS "BACKSPACE" AND HIT A DIFFERENT KEY UNTIL YOU SEE THE "Y" SHOW UP!.
Click on "Subscribe…
Did you follow this advice about formatting your USB stick?:
Hi all,
as the title suggests, some and/or many problems with your installation can be avoided by burning the ISO file at the "SLOWEST POSSIBLE SPEED", most if not all burner apps will automatically choose the fastest speed available for your disk burner drive so it is important before you commit to burn a CD/DVD that you select the menu tab which controls the burn speed and select the lowest number on offer.
Your burner drive may well support a burn speed of 20 X for DVD and 60 X for CD's a…
See also:
When you post a question in this category please use the following guide:
Search before posting
Use the magnifying glass in the right-top corner to search this community. There is a chance your question has allready been answered.
Use a good title
Do not use Help!!! Internet Not working, but use Cannot install Chrome on 15.10
Describe your problem as exact as possible
Do not post a question like how to install skype? help, but post something like After installing UM 16.04 I got the foll…
