I've installed 8 times now, and most times, I got it to start and see the desktop.
ISSUE:
On Shutdown, I get fails to unload /cdrom, and failed to unload isodevice and hangs there.
Powering off, and rebooting again, I get the login screen (first time that happened), and after logging in, I see a light-grey screen with a small darker border and after 11 seconds, the green logo, then after 48 seconds (timed it) I get a black screen sometimes with a cursor, sometimes not. The only thing that works, is the fan the black screen, and the mouse - sometimes the mouse.
How I installed:
I downloaded the cdrom/ link to get "ubuntu-mate-20.04-desktop-amd64.iso"
This was burned to a 8 Gig USB Drive using Balena-Etcher (because the first suggested Universal-USB-Installer refused to format the USB Memory Stick).
The USB Thumb Drive was inserted into the ltop and booted. That opened Pandora's Box.
Too many install fails so I re-burned the USB stick
Re-installed - again- and made it to the desktop.
There was no request to set up user, or password or to remove the USB Flash Drive.
I noted that there was a Install Ubuntu-Mate icon. I thought that was what I just installed so many times but what the h , I clicked it, and eventually, asked to set up a user name and password. That done, I did a restart and was again greeted with "Failed to unmount /cdrom and /isodevice.
Now, when I boot, I get a most private system, it's a black screen with no input from mouse, touch pad, or keyboard. No amount of old or newly invented cussing helped any.
What else have I done:
I bought a new USB dongle, re-downloaded "ubuntu-mate-20.04-desktop-amd64.iso", re-imaged to USB Pen Drive, and re-installed again.
As it turns out, there is was no opportunity to reformat, wipe, or partition the HHD, anf the Installer saw Ubu was installed, checked the files (./casper/filesystems.quashfs )), started Ubu again, with logo in centre screenand the 5 whites dots below it stay white and that is the end of that install. It hange there.
= two bricked USB (whatevers), one bricked laptop and 15 new curses to added.
What kind of laptop should I buy to make Ubuntu 20.04 install?
~s~ I'm feeling very
right now >:(
16 hours in two days I've put into this and only got as far as forced to use Windows to ask how to make Ububtu install.
Odd though, it had UBMate 16.x() on it and that installed fine when it was done. Whatever, I need to go back to my life and move on.
